Rear springs
#33
Yes Nick, if you don't put the spacer under the U bolt as well as the through bolt then it becomes necessary to shorten the U bolt, and in some cases also extend the threads on the U Bolts. You can use a short leaf from an old spring as a spacer or an appropriately sized piece of steel plate, I suggest it would be sensible to make this plate the width of the spring to avoid putting a bending load into the U bolt.
Rear springs - by Duncan Grimmond - 21-08-2019, 08:39 PM
RE: Rear springs - by Nick Lettington - 21-08-2019, 09:56 PM
RE: Rear springs - by Duncan Grimmond - 21-08-2019, 11:10 PM
RE: Rear springs - by Geoff101 - 22-08-2019, 08:01 AM
RE: Rear springs - by Bob Culver - 22-08-2019, 09:20 AM
RE: Rear springs - by AustinWood - 22-08-2019, 09:46 AM
RE: Rear springs - by Howard Wright - 22-08-2019, 10:07 AM
RE: Rear springs - by Dave Mann - 22-08-2019, 10:24 AM
RE: Rear springs - by Duncan Grimmond - 22-08-2019, 05:00 PM
RE: Rear springs - by Andy Bennett - 22-08-2019, 09:42 PM
RE: Rear springs - by Tony Press - 22-08-2019, 10:59 PM
RE: Rear springs - by Bob Culver - 23-08-2019, 12:53 AM
RE: Rear springs - by Duncan Grimmond - 23-08-2019, 09:02 AM
RE: Rear springs - by spannerman - 23-08-2019, 09:20 AM
RE: Rear springs - by Ruairidh Dunford - 23-08-2019, 09:23 AM
RE: Rear springs - by Bob Culver - 23-08-2019, 09:29 AM
RE: Rear springs - by Howard Wright - 23-08-2019, 09:43 AM
RE: Rear springs - by Duncan Grimmond - 23-08-2019, 10:05 AM
RE: Rear springs - by Dave Mann - 23-08-2019, 08:59 PM
RE: Rear springs - by Zetomagneto - 23-08-2019, 10:44 PM
RE: Rear springs - by Ian Williams - 24-08-2019, 01:16 AM
RE: Rear springs - by Tony Press - 24-08-2019, 06:53 AM
RE: Rear springs - by Duncan Grimmond - 24-08-2019, 08:34 AM
RE: Rear springs - by Duncan Grimmond - 24-08-2019, 12:25 PM
RE: Rear springs - by Ian Williams - 24-08-2019, 09:47 PM
RE: Rear springs - by Duncan Grimmond - 24-08-2019, 09:54 PM
RE: Rear springs - by Ian Williams - 24-08-2019, 09:57 PM
RE: Rear springs - by Zetomagneto - 24-08-2019, 10:12 PM
RE: Rear springs - by Duncan Grimmond - 31-08-2019, 06:20 PM
RE: Rear springs - by Nick Lettington - 31-08-2019, 06:38 PM
RE: Rear springs - by Ian Williams - 31-08-2019, 08:33 PM
RE: Rear springs - by Nick Lettington - 31-08-2019, 09:34 PM
RE: Rear springs - by Ian Williams - 31-08-2019, 09:44 PM
RE: Rear springs - by Duncan Grimmond - 31-08-2019, 10:27 PM
RE: Rear springs - by Hedd_Jones - 31-08-2019, 10:29 PM
RE: Rear springs - by Duncan Grimmond - 01-09-2019, 06:56 PM
