Fly wheel taper
Yes, 1/4 thou.
1.25" min to 1.25"+1/4 thou max on the rear - should be tight. You'd never get the bearing on at +2.5 thou. Though I'd agree with Tony Press (if I'm understanding him correctly), a tad tighter say +1/2 thou would do no harm.
1.124"+3/4 thou min to 1.125" max on the front - shouldn't be nearly as tight as the rear (or you wouldn't be able to build / dismantle the engine).
I agree it's a bit confusing but take a look at the big ends and keyways, they are dimensioned the same way e.g. 1.312" to 1.312"+ 1/2. If you look up big end diameters for Reliant side valve engines, 850 Minis etc. (which are published figures) +1/2 thou tolerance tallies exactly.
Fly wheel taper - by Tony Betts - 30-08-2019, 07:41 PM
RE: Fly wheel taper - by Charles P - 30-08-2019, 08:18 PM
RE: Fly wheel taper - by Bob Culver - 30-08-2019, 08:59 PM
RE: Fly wheel taper - by Colin Reed - 30-08-2019, 09:13 PM
RE: Fly wheel taper - by Henry Harris - 30-08-2019, 10:09 PM
RE: Fly wheel taper - by Chris KC - 30-08-2019, 10:41 PM
RE: Fly wheel taper - by Tony Betts - 30-08-2019, 10:59 PM
RE: Fly wheel taper - by Bob Culver - 31-08-2019, 01:56 AM
RE: Fly wheel taper - by Tony Press - 31-08-2019, 02:30 AM
RE: Fly wheel taper - by Chris KC - 31-08-2019, 07:48 AM
RE: Fly wheel taper - by AllAlloyCup - 31-08-2019, 09:38 AM
RE: Fly wheel taper - by Tony Griffiths - 31-08-2019, 11:01 AM
RE: Fly wheel taper - by Bob Culver - 02-09-2019, 05:33 AM
RE: Fly wheel taper - by Tony Betts - 05-09-2019, 10:14 AM
RE: Fly wheel taper - by austin - 05-09-2019, 03:22 PM
RE: Fly wheel taper - by Henry Harris - 05-09-2019, 06:12 PM
RE: Fly wheel taper - by Tony Betts - 09-09-2019, 10:12 AM
