Fly wheel taper
The SKF Manual suggests for a Cylindrical Roller Bearing on an 1.25" shaft in an Internal Combustion Engine an interference fit of +0.0003" to +0.0007" which is a little more than 1/4 of a tenth or 0.00025" on the drawing or the quoted Rear journal 1.250 - 1.25025 dia.
EG- 1.2503 - 1.2507 dia.
A fit of +0.0025- (two and a half thou)  would be quite difficult to install and most likely overload the inner ring.
Sorry +0.0007 corrected.
Yes a little tighter than Austin's tolerance would be useful.
Fly wheel taper - by Tony Betts - 30-08-2019, 07:41 PM
RE: Fly wheel taper - by Charles P - 30-08-2019, 08:18 PM
RE: Fly wheel taper - by Bob Culver - 30-08-2019, 08:59 PM
RE: Fly wheel taper - by Colin Reed - 30-08-2019, 09:13 PM
RE: Fly wheel taper - by Henry Harris - 30-08-2019, 10:09 PM
RE: Fly wheel taper - by Chris KC - 30-08-2019, 10:41 PM
RE: Fly wheel taper - by Tony Betts - 30-08-2019, 10:59 PM
RE: Fly wheel taper - by Bob Culver - 31-08-2019, 01:56 AM
RE: Fly wheel taper - by Tony Press - 31-08-2019, 02:30 AM
RE: Fly wheel taper - by Chris KC - 31-08-2019, 07:48 AM
RE: Fly wheel taper - by AllAlloyCup - 31-08-2019, 09:38 AM
RE: Fly wheel taper - by Tony Griffiths - 31-08-2019, 11:01 AM
RE: Fly wheel taper - by Bob Culver - 02-09-2019, 05:33 AM
RE: Fly wheel taper - by Tony Betts - 05-09-2019, 10:14 AM
RE: Fly wheel taper - by austin - 05-09-2019, 03:22 PM
RE: Fly wheel taper - by Henry Harris - 05-09-2019, 06:12 PM
RE: Fly wheel taper - by Tony Betts - 09-09-2019, 10:12 AM
