Steering wheel splining
#26
Hi KC,
the broaches you know from your work, are obviously the size they are. Due to production quantitys and speed.
Either that or I must have broach envy Big Grin
Bill for a one off, I don't see why a column end can't be used.
But be careful a simple branch will swell and contract the aluminium as well as cut. So it may need pushing through several times to get the splines to fit together without useing a big hammer.
Also a single size cutter will be untidy and likely to take chunks out. I'd try getting a couple or three splines. And grind the cutting heads down. So you can use them in series. Same as the correct tool.
That way you sould get a cleaner job, and less likely to have the wheel come off in you hands when you least need it to.
Good luck, Tony.
Steering wheel splining - by AllAlloyCup - 20-08-2019, 02:21 PM
RE: Steering wheel splining - by Tony Betts - 20-08-2019, 02:45 PM
RE: Steering wheel splining - by AllAlloyCup - 20-08-2019, 03:01 PM
RE: Steering wheel splining - by Davemayle - 20-08-2019, 04:44 PM
RE: Steering wheel splining - by Phil Kingdom - 20-08-2019, 04:48 PM
RE: Steering wheel splining - by Tony Betts - 20-08-2019, 04:49 PM
RE: Steering wheel splining - by Paul N-M - 20-08-2019, 04:50 PM
RE: Steering wheel splining - by AllAlloyCup - 20-08-2019, 05:15 PM
RE: Steering wheel splining - by Duncan Grimmond - 20-08-2019, 06:14 PM
RE: Steering wheel splining - by Chris KC - 20-08-2019, 06:16 PM
RE: Steering wheel splining - by Ruairidh Dunford - 20-08-2019, 06:59 PM
RE: Steering wheel splining - by AllAlloyCup - 20-08-2019, 07:11 PM
RE: Steering wheel splining - by Ruairidh Dunford - 20-08-2019, 07:18 PM
RE: Steering wheel splining - by Hedd_Jones - 20-08-2019, 09:13 PM
RE: Steering wheel splining - by Keith Dobinson - 20-08-2019, 09:28 PM
RE: Steering wheel splining - by dickie65 - 20-08-2019, 09:33 PM
RE: Steering wheel splining - by AustinWood - 21-08-2019, 08:27 AM
RE: Steering wheel splining - by Chris KC - 21-08-2019, 08:54 AM
RE: Steering wheel splining - by AllAlloyCup - 21-08-2019, 09:18 AM
RE: Steering wheel splining - by Amilcar John - 21-08-2019, 10:51 AM
RE: Steering wheel splining - by jonblob33 - 21-08-2019, 12:09 PM
RE: Steering wheel splining - by AllAlloyCup - 21-08-2019, 05:41 PM
RE: Steering wheel splining - by Tony Betts - 21-08-2019, 09:32 PM
RE: Steering wheel splining - by Chris KC - 21-08-2019, 09:55 PM
RE: Steering wheel splining - by AllAlloyCup - 21-08-2019, 10:02 PM
RE: Steering wheel splining - by Tony Betts - 21-08-2019, 10:25 PM
RE: Steering wheel splining - by Chris KC - 23-08-2019, 09:58 AM
RE: Steering wheel splining - by AllAlloyCup - 23-08-2019, 10:23 AM
RE: Steering wheel splining - by AllAlloyCup - 27-05-2020, 08:19 PM
