Renovation
Hi  Spannerman
I had the same problem with my special chassis (although this was a short wheelbase).  I seem to remember being advised to cold bend the chassis rails as heating them up could alter the metal properties.  (Do a search for the forum thread).
I achieved this using a length of 40mm square box section bolted each end to the rail with threaded rod, and then mounting a a small jack between the two.  In my case the bend was localised so the point load of a single jack was effective in bending the rail straight. I also had the luxury that the chassis was in pieces so each rail could be attacked individually.
In you case you may need to use two jacks to provide a more distributed load along the rail?
Renovation - by rubyman - 21-08-2019, 04:13 PM
RE: Renovation - by Nick Salmon - 21-08-2019, 04:51 PM
RE: Renovation - by spannerman - 21-08-2019, 05:06 PM
RE: Renovation - by Howard Wright - 21-08-2019, 05:28 PM
RE: Renovation - by Martin Prior - 21-08-2019, 06:28 PM
RE: Renovation - by Peter Naulls - 21-08-2019, 09:10 PM
RE: Renovation - by Parazine - 04-01-2021, 02:47 PM
RE: Renovation - by Denis Sweeney - 04-01-2021, 03:21 PM
RE: Renovation - by Reckless Rat - 04-01-2021, 05:09 PM
RE: Renovation - by Zetomagneto - 04-01-2021, 05:18 PM
RE: Renovation - by David Stepney - 04-01-2021, 07:37 PM
RE: Renovation - by Ruairidh Dunford - 04-01-2021, 11:06 PM
RE: Renovation - by Tony Press - 05-01-2021, 12:38 AM
