21-08-2019, 04:13 PM
Hi Lads
As part of my renovation of my ARR Ruby I have at present removed both doors (the last renovation who ever did it wasn't done very well the hinge bolts was a right assortment of unf,metric. and unc, now replaced with 1/4 inch bsf, bolts used as hinge pins now replaced with dowel pins).
I have stained all the wood work which is in good condition and under sealed the inner side of the panels, I now have no play in the hinge's but the drivers door as dropped about a inch when closed the line down the side of the Ruby dose not line up I have tried putting a spacer behind the hinge but that dose not line it up.
Has any members been successful in over coming this problem in lining up the door, also thinking of fitting the door cards with chrome headed self tapper's with cup washers instead of the nails.
What do you think ?
Thanks for all repliesĀ
Graham in Sheffield
What do you think ?
Graham in Sheffield
