  • 1 Vote(s) - 2 Average
New Member Restoring Ruby
I believe that the original fitting to the Ruby series cars was a Lucas DK4 distributor which gives 8 degrees advance. Earlier cars has a Lucas DJ distributor which has no centrifugal advance and relied on manual adjustment via the column lever. A manually adjusted dizzy should be set at full retard for starting and then advanced when on the move. Advance is clockwise relative to the distributor body and its base. The column levers may have been reversed!
New Member Restoring Ruby - by NICKADAM - 12-08-2019, 02:42 PM
RE: New Member Restoring Ruby - by Bill Dixon - 12-08-2019, 03:00 PM
RE: New Member Restoring Ruby - by Robert Leigh - 12-08-2019, 03:23 PM
RE: New Member Restoring Ruby - by Martin Paul - 12-08-2019, 03:30 PM
RE: New Member Restoring Ruby - by Hugh Barnes - 12-08-2019, 04:38 PM
RE: New Member Restoring Ruby - by Derek Sheldon - 12-08-2019, 06:18 PM
RE: New Member Restoring Ruby - by GK5268 - 12-08-2019, 06:25 PM
RE: New Member Restoring Ruby - by Chris KC - 12-08-2019, 07:04 PM
RE: New Member Restoring Ruby - by Andy Bennett - 12-08-2019, 08:04 PM
RE: New Member Restoring Ruby - by NICKADAM - 15-08-2019, 09:53 AM
RE: New Member Restoring Ruby - by Reckless Rat - 15-08-2019, 11:22 AM
RE: New Member Restoring Ruby - by Andy Bennett - 15-08-2019, 11:42 AM
RE: New Member Restoring Ruby - by Hugh Barnes - 15-08-2019, 02:05 PM
RE: New Member Restoring Ruby - by Bob Culver - 15-08-2019, 05:56 PM
RE: New Member Restoring Ruby - by Jeff Taylor - 15-08-2019, 09:55 PM
RE: New Member Restoring Ruby - by flywheel1935 - 17-08-2019, 09:58 PM
RE: New Member Restoring Ruby - by James Anderson - 18-08-2019, 05:19 PM
RE: New Member Restoring Ruby - by Nigel Ricardo - 18-08-2019, 06:30 PM
RE: New Member Restoring Ruby - by Tony Press - 18-08-2019, 11:27 PM
RE: New Member Restoring Ruby - by David Stepney - 18-08-2019, 11:45 PM
RE: New Member Restoring Ruby - by Tony Press - 18-08-2019, 11:56 PM
RE: New Member Restoring Ruby - by David Stepney - 19-08-2019, 12:21 AM
RE: New Member Restoring Ruby - by Tony Press - 19-08-2019, 06:01 AM
RE: New Member Restoring Ruby - by Andy Bennett - 19-08-2019, 08:24 AM
RE: New Member Restoring Ruby - by Nick Salmon - 19-08-2019, 09:03 AM
RE: New Member Restoring Ruby - by Bruce Nicholls - 19-08-2019, 10:26 AM
RE: New Member Restoring Ruby - by David Stepney - 19-08-2019, 10:27 AM
RE: New Member Restoring Ruby - by Andy Bennett - 19-08-2019, 05:19 PM
RE: New Member Restoring Ruby - by Alan - 19-08-2019, 06:51 PM
RE: New Member Restoring Ruby - by Steve Jones - 19-08-2019, 07:32 PM
RE: New Member Restoring Ruby - by Alan - 19-08-2019, 07:35 PM
