14-08-2019, 09:34 PM
I don't have a definitive answer for you Chris as I have never had to correct a carrier with excessively loose or worn pins. Agree that they are secured by a pin through the casting and as a result it would be possible to remove and replace them, I also agree that the other end of the pin is supported by the opposite side of the carrier. You might be able to replace the loose pins with some from a better carrier but I anticipate that the hole on the casting will have wear as well so it would likely entail making completely new pins oversize where they fit the casting!... Not sure I would go to the trouble. When you assemble the two halves of the carrier are the pins still noticeably loose or is it only apparent when the carrier is split, if the latter I would not worry about it, if the former, well personally I would rummage in the spares shed.
