The Brookfields Special
#34
Hi All
Been Kerfing and swearing today.  After a few days making the seat frame and front floor sections I bit the bullet and had a go at fitting the side ply panels.  These will be attacked with a hole and jig saw to make a ply skeleton over which some thin ply will be glued.
The ply is 12mm and even so needed "kerfing" cuts at about 3/4" to pull into the curve at the rear of the car.  Next stage is to glue the kerfed ply and leave for a day or so before cutting into it. I'll be busy doing the other side and seeing if I can "Kerf" the scuttle top.  There is quite a sharp curve here and I may have to build up by glueing thinner ply together.
The Brookfields Special - by Howard Wright - 13-07-2019, 06:27 PM
RE: The Brookfields Special - by Rick F - 14-07-2019, 12:38 AM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 08:39 AM
RE: The Brookfields Special - by JonE - 14-07-2019, 09:16 AM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 11:18 AM
RE: The Brookfields Special - by Ivor Hawkins - 14-07-2019, 04:29 PM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 06:16 PM
RE: The Brookfields Special - by Steve kay - 15-07-2019, 12:47 PM
RE: The Brookfields Special - by Howard Wright - 15-07-2019, 06:02 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 05:58 PM
RE: The Brookfields Special - by Terrytuned - 18-07-2019, 07:27 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 08:09 PM
RE: The Brookfields Special - by Terrytuned - 18-07-2019, 09:01 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 10:00 PM
RE: The Brookfields Special - by Howard Wright - 20-07-2019, 08:33 PM
RE: The Brookfields Special - by Howard Wright - 08-08-2019, 07:38 AM
RE: The Brookfields Special - by Duncan Grimmond - 09-08-2019, 08:10 AM
RE: The Brookfields Special - by Howard Wright - 09-08-2019, 09:51 AM
RE: The Brookfields Special - by AllAlloyCup - 09-08-2019, 04:08 PM
RE: The Brookfields Special - by phillips - 09-08-2019, 04:34 PM
RE: The Brookfields Special - by Duncan Grimmond - 09-08-2019, 10:05 PM
RE: The Brookfields Special - by Tony Press - 09-08-2019, 11:54 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 09:39 AM
RE: The Brookfields Special - by Roger Goldthorpe - 10-08-2019, 09:46 AM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 09:57 AM
RE: The Brookfields Special - by Mike Costigan - 10-08-2019, 12:43 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 03:04 PM
RE: The Brookfields Special - by Malcolm Parker - 10-08-2019, 03:44 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 03:53 PM
RE: The Brookfields Special - by stuartu - 10-08-2019, 05:26 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 05:52 PM
RE: The Brookfields Special - by Barry - 11-08-2019, 10:03 PM
RE: The Brookfields Special - by Duncan Grimmond - 11-08-2019, 11:01 PM
RE: The Brookfields Special - by Howard Wright - 12-08-2019, 05:56 PM
RE: The Brookfields Special - by Ian Williams - 12-08-2019, 10:14 PM
RE: The Brookfields Special - by Duncan Grimmond - 13-08-2019, 12:08 AM
RE: The Brookfields Special - by Howard Wright - 13-08-2019, 07:35 AM
RE: The Brookfields Special - by Howard Wright - 20-08-2019, 01:23 PM
RE: The Brookfields Special - by Steve Jones - 20-08-2019, 01:47 PM
RE: The Brookfields Special - by Duncan Grimmond - 20-08-2019, 07:29 PM
RE: The Brookfields Special - by Howard Wright - 20-08-2019, 11:49 PM
RE: The Brookfields Special - by Howard Wright - 26-08-2019, 05:53 PM
RE: The Brookfields Special - by Nick Salmon - 27-08-2019, 02:53 PM
RE: The Brookfields Special - by Reckless Rat - 27-08-2019, 03:11 PM
RE: The Brookfields Special - by Nick Lettington - 27-08-2019, 03:19 PM
RE: The Brookfields Special - by Howard Wright - 27-08-2019, 06:30 PM
RE: The Brookfields Special - by Howard Wright - 31-08-2019, 06:56 PM
RE: The Brookfields Special - by Howard Wright - 13-09-2019, 06:49 PM
RE: The Brookfields Special - by Ian Williams - 13-09-2019, 09:28 PM
RE: The Brookfields Special - by Howard Wright - 14-09-2019, 06:55 AM
RE: The Brookfields Special - by Jamie - 14-09-2019, 11:29 AM
RE: The Brookfields Special - by Duncan Grimmond - 14-09-2019, 12:26 PM
RE: The Brookfields Special - by Howard Wright - 14-09-2019, 05:57 PM
RE: The Brookfields Special - by Duncan Grimmond - 14-09-2019, 06:24 PM
RE: The Brookfields Special - by Jamie - 15-09-2019, 09:34 AM
RE: The Brookfields Special - by Howard Wright - 21-09-2019, 06:33 PM
RE: The Brookfields Special - by Duncan Grimmond - 21-09-2019, 06:44 PM
RE: The Brookfields Special - by DavidL - 22-09-2019, 05:44 PM
RE: The Brookfields Special - by Howard Wright - 22-09-2019, 07:31 PM
RE: The Brookfields Special - by Duncan Grimmond - 22-09-2019, 10:29 PM
RE: The Brookfields Special - by DavidL - 28-09-2019, 10:20 PM
RE: The Brookfields Special - by David Stepney - 28-09-2019, 10:38 PM
RE: The Brookfields Special - by Spex - 28-09-2019, 10:51 PM
RE: The Brookfields Special - by David Stepney - 28-09-2019, 11:13 PM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 12:26 AM
RE: The Brookfields Special - by Howard Wright - 29-09-2019, 07:51 AM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 09:01 AM
RE: The Brookfields Special - by Howard Wright - 29-09-2019, 09:50 AM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 01:36 PM
RE: The Brookfields Special - by Howard Wright - 02-10-2019, 06:46 PM
RE: The Brookfields Special - by Charles P - 02-10-2019, 06:57 PM
RE: The Brookfields Special - by Reckless Rat - 02-10-2019, 08:21 PM
RE: The Brookfields Special - by Howard Wright - 02-10-2019, 08:49 PM
RE: The Brookfields Special - by DavidL - 02-10-2019, 11:44 PM
RE: The Brookfields Special - by David Stepney - 03-10-2019, 12:07 AM
RE: The Brookfields Special - by Howard Wright - 10-10-2019, 06:41 PM
RE: The Brookfields Special - by David Stepney - 10-10-2019, 09:25 PM
RE: The Brookfields Special - by Duncan Grimmond - 12-10-2019, 06:00 PM
RE: The Brookfields Special - by Howard Wright - 12-10-2019, 06:46 PM
RE: The Brookfields Special - by Howard Wright - 20-10-2019, 06:41 PM
RE: The Brookfields Special - by Duncan Grimmond - 22-10-2019, 10:52 AM
RE: The Brookfields Special - by Howard Wright - 08-11-2019, 06:59 PM
RE: The Brookfields Special - by Nick Salmon - 08-11-2019, 07:23 PM
RE: The Brookfields Special - by Reckless Rat - 08-11-2019, 07:47 PM
RE: The Brookfields Special - by Duncan Grimmond - 08-11-2019, 09:51 PM
RE: The Brookfields Special - by Howard Wright - 23-11-2019, 05:26 PM
RE: The Brookfields Special - by Ashleyvincent - 23-11-2019, 06:23 PM
RE: The Brookfields Special - by Duncan Grimmond - 23-11-2019, 07:07 PM
RE: The Brookfields Special - by Dennis Nicholas - 30-11-2019, 01:11 AM
RE: The Brookfields Special - by Howard Wright - 30-11-2019, 10:22 AM
RE: The Brookfields Special - by Duncan Grimmond - 30-11-2019, 12:19 PM
RE: The Brookfields Special - by Howard Wright - 11-12-2019, 05:35 PM
RE: The Brookfields Special - by Duncan Grimmond - 11-12-2019, 09:03 PM
RE: The Brookfields Special - by Howard Wright - 20-01-2020, 07:33 PM
RE: The Brookfields Special - by JonE - 20-01-2020, 08:27 PM
RE: The Brookfields Special - by Dennis Nicholas - 21-01-2020, 05:29 PM
RE: The Brookfields Special - by Howard Wright - 29-01-2020, 07:13 PM
RE: The Brookfields Special - by JonE - 29-01-2020, 07:34 PM
RE: The Brookfields Special - by Howard Wright - 29-01-2020, 07:47 PM
RE: The Brookfields Special - by squeak - 29-01-2020, 11:21 PM
RE: The Brookfields Special - by Howard Wright - 01-02-2020, 08:49 PM
RE: The Brookfields Special - by Duncan Grimmond - 02-02-2020, 01:10 PM
RE: The Brookfields Special - by Greig Smith - 02-02-2020, 04:30 PM
RE: The Brookfields Special - by Howard Wright - 02-02-2020, 06:01 PM
RE: The Brookfields Special - by Howard Wright - 07-02-2020, 09:04 PM
RE: The Brookfields Special - by Chris Garner - 08-02-2020, 09:19 AM
RE: The Brookfields Special - by Duncan Grimmond - 08-02-2020, 06:41 PM
RE: The Brookfields Special - by Ruairidh Dunford - 08-02-2020, 06:52 PM
RE: The Brookfields Special - by Greig Smith - 08-02-2020, 08:42 PM
RE: The Brookfields Special - by Howard Wright - 08-02-2020, 10:11 PM
RE: The Brookfields Special - by Chris Garner - 09-02-2020, 11:24 AM
RE: The Brookfields Special - by Howard Wright - 09-02-2020, 02:39 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 08:38 PM
RE: The Brookfields Special - by JonE - 20-03-2020, 09:24 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 09:46 PM
RE: The Brookfields Special - by Mike Costigan - 20-03-2020, 10:13 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 10:17 PM
RE: The Brookfields Special - by Duncan Grimmond - 20-03-2020, 11:52 PM
RE: The Brookfields Special - by Howard Wright - 21-03-2020, 08:17 AM
RE: The Brookfields Special - by NBS - 21-03-2020, 08:38 AM
RE: The Brookfields Special - by JonE - 22-03-2020, 09:55 AM
RE: The Brookfields Special - by Colin Reed - 22-03-2020, 10:32 AM
RE: The Brookfields Special - by Howard Wright - 22-03-2020, 11:04 AM
RE: The Brookfields Special - by Duncan Grimmond - 22-03-2020, 12:23 PM
RE: The Brookfields Special - by Michael D - 22-03-2020, 02:15 PM
RE: The Brookfields Special - by Howard Wright - 30-03-2020, 10:41 AM
RE: The Brookfields Special - by Howard Wright - 17-05-2020, 05:54 PM
RE: The Brookfields Special - by Duncan Grimmond - 17-05-2020, 06:05 PM
