Front and rear inner hubs
As was often the case, there are some 'transitional' cars about.  The full Girling brakes with the heavier hub is given in Wyatt as being introduced at 286571, with the dowels being removed from the brake drums at 287828.  My car at 287777 has the heavy hubs with dowelled wheels/drums - the only difference in the drums from the normal semi-Girling is that the centre hole is opened up slightly to take the heavier hub - it therefore takes earlier wheels.  The bearing in the front hub is unchanged from the semi-Girling size.
Colin
Front and rear inner hubs - by John Mims - 04-08-2019, 09:33 PM
RE: Front and rear inner hubs - by Ian Williams - 04-08-2019, 09:47 PM
RE: Front and rear inner hubs - by John Mims - 04-08-2019, 09:54 PM
RE: Front and rear inner hubs - by Bob Culver - 06-08-2019, 12:52 AM
RE: Front and rear inner hubs - by squeak - 06-08-2019, 01:08 AM
RE: Front and rear inner hubs - by Tony Press - 06-08-2019, 02:25 AM
RE: Front and rear inner hubs - by Stuart Giles - 06-08-2019, 08:33 AM
RE: Front and rear inner hubs - by Colin Morgan - 06-08-2019, 10:25 AM
RE: Front and rear inner hubs - by Tony Press - 06-08-2019, 11:21 PM
