Austin seven special Fabric body
Hello Andrew,
                   Irish Linen is the best traditional material and it works best with Nitrate Dope, which is flammable. Butyrate Dope a cellulose based product is a 'less' flammable and an effective alternative.
Both will shrink the fabric, but you need to be mindful that as the plasticisers in them bleed off over the years they will continue to shrink! Butyrate is better with this as you can refresh it as it ages.
Irish Linen of the correct standard is manufactured to BS 9F 1 - 1992, which is for aircraft, it is a very strong material and available from a company in Belgium at about £20 per meter. Contact is Christine Debaes on +32 51 262870.
Regards,
            Mark.
Austin seven special Fabric body - by daglocks - 07-11-2017, 06:38 PM
RE: Austin seven special Fabric body - by GK5268 - 07-11-2017, 09:10 PM
RE: Austin seven special Fabric body - by Mark Atkinson - 08-11-2017, 01:19 AM
