Four Blade Fan
I rather suspect that the Austin Seven fan does more stirring than sucking.
It needs to be close to the radiator and would benefit from a cowl to allow it to generate a low pressure region behind the rad.
Neither really feasible on the Austin.
For much of the year I run with no fan belt. Only a slight problem if in stationary traffic. If there's hot sunny weather I refit it if I remember.
My fabric saloon has solid radiator sides which must impede the flow. Usually the hot air comes up around the gearbox into the car. I cover that up in summer as it overheats the occupants. Nice in winter though so long as not exceeding 45mph, when the cold air takes over.
Four Blade Fan - by Colin Morgan - 25-07-2019, 08:55 PM
RE: Four Blade Fan - by Colin Morgan - 29-07-2019, 12:29 PM
RE: Four Blade Fan - by Mark McKibbin - 29-07-2019, 12:51 PM
RE: Four Blade Fan - by Colin Morgan - 29-07-2019, 01:24 PM
RE: Four Blade Fan - by Duncan Grimmond - 29-07-2019, 01:28 PM
RE: Four Blade Fan - by Colin Morgan - 29-07-2019, 01:39 PM
RE: Four Blade Fan - by Robert Leigh - 29-07-2019, 06:20 PM
RE: Four Blade Fan - by Hedd_Jones - 29-07-2019, 06:21 PM
RE: Four Blade Fan - by Colin Morgan - 29-07-2019, 09:47 PM
RE: Four Blade Fan - by Mark McKibbin - 30-07-2019, 04:34 AM
RE: Four Blade Fan - by Colin Morgan - 30-07-2019, 10:43 AM
RE: Four Blade Fan - by AustinWood - 30-07-2019, 11:19 AM
RE: Four Blade Fan - by Steve Jones - 30-07-2019, 11:30 AM
RE: Four Blade Fan - by Colin Morgan - 30-07-2019, 11:43 AM
RE: Four Blade Fan - by Reckless Rat - 30-07-2019, 11:50 AM
RE: Four Blade Fan - by John Mason - 30-07-2019, 12:15 PM
RE: Four Blade Fan - by Colin Morgan - 30-07-2019, 01:02 PM
