  • 3 Vote(s) - 4 Average
Building a Special Body
#71
Hi Matt,
On the Joss Cambell car as you note there were very few modifications other that converting to Austin spec sports suspension, for a fast road and occasional hill climb car I have found this to be completely adequate, and perhaps more importantly it is totally period correct so no raised eyebrows or issues with eligibility. My own car has developed and evolved over 35 years of hard use both road and track, in its original form it had a completely unboxed chassis and served me well for a while. As I went faster I started to have issues, the most annoying was jacking the inside rear wheel loosing drive round quick tight corners, this was solved by boxing the chassis, improving dampers and playing with spring rates. This time I have evolved the chassis further, improving the boxing and adding members to attach the undertray and floor, I have tried to keep the construction reasonably period authentic and not add undue weight hence the use of hot riveted construction and copying the style of the existing central stiffer. I hope that is of help.
Building a Special Body - by Ian Williams - 12-10-2017, 03:46 AM
RE: Building a Special Body - by Charles P - 12-10-2017, 08:14 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 08:44 AM
RE: Building a Special Body - by Dave Wortley - 12-10-2017, 09:42 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 10:00 AM
RE: Building a Special Body - by Ian Williams - 12-10-2017, 10:07 AM
RE: Building a Special Body - by Mark Atkinson - 12-10-2017, 09:04 PM
RE: Building a Special Body - by Timothy P - 12-10-2017, 10:54 PM
RE: Building a Special Body - by Erich - 14-10-2017, 03:23 PM
RE: Building a Special Body - by Ian Williams - 15-10-2017, 03:46 AM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 01:52 AM
RE: Building a Special Body - by Erich - 01-11-2017, 05:02 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 05:28 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 08:03 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 10:00 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 11:09 PM
RE: Building a Special Body - by Erich - 01-11-2017, 11:55 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 03:38 AM
RE: Building a Special Body - by Timothy P - 02-11-2017, 05:43 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 08:03 PM
RE: Building a Special Body - by Timothy P - 02-11-2017, 08:43 PM
RE: Building a Special Body - by Duncan Grimmond - 03-11-2017, 09:42 AM
RE: Building a Special Body - by Albert S - 04-11-2017, 09:56 AM
RE: Building a Special Body - by Ian Williams - 04-11-2017, 08:49 PM
RE: Building a Special Body - by Ian Williams - 06-02-2018, 08:58 PM
RE: Building a Special Body - by JonE - 06-02-2018, 11:30 PM
RE: Building a Special Body - by Erich - 07-02-2018, 04:53 AM
RE: Building a Special Body - by merlinart - 07-02-2018, 10:17 AM
RE: Building a Special Body - by Ian Williams - 09-02-2018, 09:14 PM
RE: Building a Special Body - by John Bonnett - 11-02-2018, 09:59 AM
RE: Building a Special Body - by Ian Williams - 11-02-2018, 09:07 PM
RE: Building a Special Body - by Nick Turley - 11-02-2018, 02:36 PM
RE: Building a Special Body - by Duncan Grimmond - 11-02-2018, 04:29 PM
RE: Building a Special Body - by John Bonnett - 12-02-2018, 08:46 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:00 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 09:26 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:42 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:02 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 11:06 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:49 PM
RE: Building a Special Body - by Charles P - 13-02-2018, 07:07 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 01:45 AM
RE: Building a Special Body - by John Bonnett - 20-02-2018, 08:44 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 08:09 PM
RE: Building a Special Body - by Ian Williams - 30-06-2018, 12:43 AM
RE: Building a Special Body - by Jamie - 30-06-2018, 08:49 AM
RE: Building a Special Body - by jansens - 02-07-2018, 06:44 PM
RE: Building a Special Body - by Duncan Grimmond - 02-07-2018, 07:20 PM
RE: Building a Special Body - by jansens - 03-07-2018, 12:19 AM
RE: Building a Special Body - by Ian Williams - 03-07-2018, 08:53 AM
RE: Building a Special Body - by Belinni - 08-04-2019, 12:37 PM
RE: Building a Special Body - by Ian Williams - 08-04-2019, 08:35 PM
RE: Building a Special Body - by squeak - 09-04-2019, 12:40 AM
RE: Building a Special Body - by Timothy P - 09-04-2019, 09:49 AM
RE: Building a Special Body - by Mark Atkinson - 09-04-2019, 10:07 AM
RE: Building a Special Body - by Belinni - 10-04-2019, 12:52 PM
RE: Building a Special Body - by Ian Williams - 18-05-2019, 05:54 AM
RE: Building a Special Body - by DavidL - 19-05-2019, 04:58 PM
RE: Building a Special Body - by Jays - 19-05-2019, 08:47 PM
RE: Building a Special Body - by Ian Williams - 20-05-2019, 05:03 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 05:43 AM
RE: Building a Special Body - by Howard Wright - 17-07-2019, 07:37 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 09:25 PM
RE: Building a Special Body - by Tony Press - 18-07-2019, 07:45 AM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 03:05 AM
RE: Building a Special Body - by JonE - 23-07-2019, 08:45 PM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 09:39 PM
RE: Building a Special Body - by Jamie - 24-07-2019, 07:34 AM
RE: Building a Special Body - by goodwoodweirdo - 24-07-2019, 02:53 PM
RE: Building a Special Body - by Ian Williams - 24-07-2019, 09:34 PM
RE: Building a Special Body - by Ian Williams - 26-07-2019, 04:34 AM
RE: Building a Special Body - by goodwoodweirdo - 29-07-2019, 03:50 PM
RE: Building a Special Body - by Chris KC - 05-08-2019, 08:21 PM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 02:27 AM
RE: Building a Special Body - by Howard Wright - 15-08-2019, 07:23 AM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 08:09 AM
RE: Building a Special Body - by Ian Williams - 24-08-2019, 09:52 PM
RE: Building a Special Body - by Ian Williams - 31-08-2019, 04:38 AM
RE: Building a Special Body - by Duncan Grimmond - 31-08-2019, 08:20 AM
RE: Building a Special Body - by Steve Bryant - 31-08-2019, 02:00 PM
RE: Building a Special Body - by wild_willy - 01-09-2019, 01:18 AM
RE: Building a Special Body - by Ian Williams - 01-09-2019, 01:52 AM
RE: Building a Special Body - by Jeff Taylor - 01-09-2019, 11:21 AM
RE: Building a Special Body - by David.H - 01-09-2019, 11:35 AM
RE: Building a Special Body - by wild_willy - 01-09-2019, 12:43 PM
RE: Building a Special Body - by Ian Williams - 01-12-2019, 02:14 AM
RE: Building a Special Body - by Paul N-M - 01-12-2019, 02:13 PM
RE: Building a Special Body - by Steve Bryant - 02-12-2019, 02:56 PM
RE: Building a Special Body - by sebring115 - 02-12-2019, 04:13 PM
RE: Building a Special Body - by Ian Williams - 03-12-2019, 08:35 PM
RE: Building a Special Body - by Peter Naulls - 03-12-2019, 10:07 PM
RE: Building a Special Body - by vintage_racing - 04-12-2019, 09:55 AM
RE: Building a Special Body - by Ian Williams - 04-12-2019, 08:05 PM
RE: Building a Special Body - by Peter Naulls - 04-12-2019, 09:35 PM
RE: Building a Special Body - by sebring115 - 05-12-2019, 11:03 AM
RE: Building a Special Body - by Renaud - 08-12-2019, 01:43 PM
RE: Building a Special Body - by Ian Williams - 08-12-2019, 08:52 PM
RE: Building a Special Body - by Renaud - 10-12-2019, 06:44 PM
RE: Building a Special Body - by Ian Williams - 10-12-2019, 07:46 PM
RE: Building a Special Body - by Reckless Rat - 10-12-2019, 08:45 PM
RE: Building a Special Body - by Renaud - 11-12-2019, 09:24 AM
RE: Building a Special Body - by Reckless Rat - 11-12-2019, 11:54 AM
RE: Building a Special Body - by Ian Williams - 11-12-2019, 11:46 PM
RE: Building a Special Body - by Duncan Grimmond - 12-12-2019, 03:15 PM
RE: Building a Special Body - by Renaud - 12-12-2019, 06:43 PM
RE: Building a Special Body - by Charles P - 12-12-2019, 07:34 PM
RE: Building a Special Body - by Reckless Rat - 12-12-2019, 08:29 PM
RE: Building a Special Body - by Ian Williams - 12-12-2019, 10:40 PM
RE: Building a Special Body - by Reckless Rat - 13-12-2019, 08:55 AM
RE: Building a Special Body - by Steve Bryant - 13-12-2019, 03:51 PM
RE: Building a Special Body - by Ian Williams - 13-01-2020, 01:17 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 09:09 AM
RE: Building a Special Body - by Hentzant - 13-01-2020, 11:20 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 07:00 PM
RE: Building a Special Body - by jansens - 15-01-2020, 07:51 PM
RE: Building a Special Body - by Ian Williams - 24-01-2020, 10:17 AM
RE: Building a Special Body - by Ian Williams - 26-01-2020, 08:07 AM
RE: Building a Special Body - by Duncan Grimmond - 27-01-2020, 09:21 AM
RE: Building a Special Body - by Tony Betts - 27-01-2020, 11:41 AM
RE: Building a Special Body - by jansens - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Ian Williams - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Renaud - 28-01-2020, 07:34 AM
RE: Building a Special Body - by jansens - 28-01-2020, 08:04 AM
RE: Building a Special Body - by Bobski - 28-01-2020, 10:25 AM
RE: Building a Special Body - by Charles P - 28-01-2020, 12:03 PM
RE: Building a Special Body - by Paul N-M - 28-01-2020, 06:37 PM
RE: Building a Special Body - by Ian Williams - 28-01-2020, 09:05 PM
RE: Building a Special Body - by Renaud - 30-01-2020, 07:22 PM
RE: Building a Special Body - by Ian Williams - 30-01-2020, 07:42 PM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 03:55 AM
RE: Building a Special Body - by Spex - 05-04-2020, 06:24 AM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 08:07 AM
RE: Building a Special Body - by Renaud - 05-04-2020, 08:19 AM
RE: Building a Special Body - by Ian Williams - 10-04-2020, 02:29 AM
RE: Building a Special Body - by Renaud - 10-04-2020, 12:44 PM
RE: Building a Special Body - by flywheel1935 - 10-04-2020, 01:05 PM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 08:34 AM
RE: Building a Special Body - by flywheel1935 - 11-04-2020, 10:19 AM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 10:59 AM
RE: Building a Special Body - by Peter Sweeney - 11-04-2020, 11:30 AM
RE: Building a Special Body - by Cliff Ringrose - 11-04-2020, 04:10 PM
RE: Building a Special Body - by Ian Williams - 14-04-2020, 07:03 AM
RE: Building a Special Body - by flywheel1935 - 14-04-2020, 11:08 AM
RE: Building a Special Body - by Bruce Nicholls - 16-04-2020, 05:06 PM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 01:51 AM
RE: Building a Special Body - by Tony Press - 21-04-2020, 02:15 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 07:26 AM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 10:39 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 12:57 PM
RE: Building a Special Body - by Ian Williams - 23-04-2020, 02:57 AM
RE: Building a Special Body - by Ivor Hawkins - 23-04-2020, 08:39 AM
RE: Building a Special Body - by Ian Williams - 24-04-2020, 11:11 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 05:12 AM
RE: Building a Special Body - by jpsmit - 25-04-2020, 02:35 PM
RE: Building a Special Body - by Peter Naulls - 25-04-2020, 09:43 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 09:56 PM
RE: Building a Special Body - by Steve Bryant - 01-01-2023, 11:21 PM
RE: Building a Special Body - by Ian Williams - 02-01-2023, 08:10 AM
