distributor timing
There is much to be said for manual advance. With Sevens the acceleration allows ample time for any adjustment!
For those curious it is not difficult to rig a temporary manual override using the throttle control cable assembly from an old lawnmower etc. As most pulling  is done in the 2000 to 3500 rev range, once under reasonable way the range of adjustment required is very small , only 2 to maybe 5 crank degrees.
distributor timing - by steve62008 - 21-07-2019, 07:22 AM
RE: distributor timing - by Reckless Rat - 21-07-2019, 07:53 AM
RE: distributor timing - by Malcolm Parker - 21-07-2019, 09:06 AM
RE: distributor timing - by Hedd_Jones - 21-07-2019, 01:08 PM
RE: distributor timing - by Bob Culver - 21-07-2019, 08:40 PM
RE: distributor timing - by John Mason - 21-07-2019, 09:22 PM
RE: distributor timing - by Chris KC - 21-07-2019, 10:10 PM
RE: distributor timing - by Ian Williams - 21-07-2019, 11:10 PM
RE: distributor timing - by Bob Culver - 21-07-2019, 11:25 PM
RE: distributor timing - by Bob Culver - 22-07-2019, 07:03 AM
RE: distributor timing - by Reckless Rat - 22-07-2019, 07:40 AM
RE: distributor timing - by Chris KC - 22-07-2019, 09:47 AM
RE: distributor timing - by Bob Culver - 23-07-2019, 10:32 AM
RE: distributor timing - by Reckless Rat - 23-07-2019, 11:07 AM
