distributor timing
Assuming you've got a Lucas DK distributor with auto advance, set n°1 piston at Top Dead Centre using the marks on the flywheel and checking with the plug removed that its on compression stroke. The rotor arm should be pointing at n°1 lead on the cap and the points just opening. The engine should start. You might have to fine tune from there but once its ok lock everything off on the base plate.
distributor timing - by steve62008 - 21-07-2019, 07:22 AM
RE: distributor timing - by Reckless Rat - 21-07-2019, 07:53 AM
RE: distributor timing - by Malcolm Parker - 21-07-2019, 09:06 AM
RE: distributor timing - by Hedd_Jones - 21-07-2019, 01:08 PM
RE: distributor timing - by Bob Culver - 21-07-2019, 08:40 PM
RE: distributor timing - by John Mason - 21-07-2019, 09:22 PM
RE: distributor timing - by Chris KC - 21-07-2019, 10:10 PM
RE: distributor timing - by Ian Williams - 21-07-2019, 11:10 PM
RE: distributor timing - by Bob Culver - 21-07-2019, 11:25 PM
RE: distributor timing - by Bob Culver - 22-07-2019, 07:03 AM
RE: distributor timing - by Reckless Rat - 22-07-2019, 07:40 AM
RE: distributor timing - by Chris KC - 22-07-2019, 09:47 AM
RE: distributor timing - by Bob Culver - 23-07-2019, 10:32 AM
RE: distributor timing - by Reckless Rat - 23-07-2019, 11:07 AM
