Cylinder Block height
Chris,
Thanks for reply It did not occur to me to only use the shim, that will maintain the original height if I use a 0.020” shim.
I guess the ally will be soft enough to compress a little and fit any irregularities in the surface under the block.
I will not be fitting this till the winter weather arrives so just wanted to make sure it was all sorted in advance.
Roger
Cylinder Block height - by Roger - 14-07-2019, 10:12 PM
RE: Cylinder Block height - by Ruairidh Dunford - 14-07-2019, 10:27 PM
RE: Cylinder Block height - by Alan - 14-07-2019, 10:44 PM
RE: Cylinder Block height - by Roger - 14-07-2019, 11:09 PM
RE: Cylinder Block height - by Ruairidh Dunford - 14-07-2019, 11:14 PM
RE: Cylinder Block height - by Roger - 14-07-2019, 11:16 PM
RE: Cylinder Block height - by Chris KC - 15-07-2019, 08:43 AM
RE: Cylinder Block height - by Roger - 15-07-2019, 09:00 AM
RE: Cylinder Block height - by Chris KC - 15-07-2019, 10:05 AM
RE: Cylinder Block height - by spannerman - 15-07-2019, 07:27 PM
