Cylinder Block height
Can’t answer your question exactly, but you ought to be setting the piston height anyway. With a standard gasket, and new crankshaft I aim to have the pistons level with the top of the bores. You can skim the tops of the pistons to achieve this, but remember it’s good if they all still weigh the same. With old cranks that whip a lot at high revs you might want to be as much as 20 thou below block height.
Cylinder Block height - by Roger - 14-07-2019, 10:12 PM
RE: Cylinder Block height - by Ruairidh Dunford - 14-07-2019, 10:27 PM
RE: Cylinder Block height - by Alan - 14-07-2019, 10:44 PM
RE: Cylinder Block height - by Roger - 14-07-2019, 11:09 PM
RE: Cylinder Block height - by Ruairidh Dunford - 14-07-2019, 11:14 PM
RE: Cylinder Block height - by Roger - 14-07-2019, 11:16 PM
RE: Cylinder Block height - by Chris KC - 15-07-2019, 08:43 AM
RE: Cylinder Block height - by Roger - 15-07-2019, 09:00 AM
RE: Cylinder Block height - by Chris KC - 15-07-2019, 10:05 AM
RE: Cylinder Block height - by spannerman - 15-07-2019, 07:27 PM
