Oil leak
Is the oil leaking through a hole in the bottom of the torque tube at the mid point, Duncan (there shouldn't be any hole but maybe someone's drilled one as a drain point) or is it leaking from the joint of the torque tube and the axle casing and running down the outside/underside of the torque tube until it drips off at the mid point? Also, what is the angle of the torque tube?
Oil leak - by Duncan Grimmond - 03-07-2019, 03:09 PM
RE: Oil leak - by Chris KC - 03-07-2019, 03:18 PM
RE: Oil leak - by Terrytuned - 03-07-2019, 04:18 PM
RE: Oil leak - by Duncan Grimmond - 03-07-2019, 06:20 PM
RE: Oil leak - by Terrytuned - 03-07-2019, 08:05 PM
RE: Oil leak - by Duncan Grimmond - 03-07-2019, 09:39 PM
RE: Oil leak - by Chris KC - 03-07-2019, 10:17 PM
RE: Oil leak - by Duncan Grimmond - 04-07-2019, 06:11 PM
RE: Oil leak - by Chris KC - 04-07-2019, 06:27 PM
RE: Oil leak - by Duncan Grimmond - 05-07-2019, 08:17 PM
RE: Oil leak - by Duncan Grimmond - 09-07-2019, 09:02 AM
RE: Oil leak - by Steve Jones - 09-07-2019, 10:58 AM
RE: Oil leak - by Terrytuned - 09-07-2019, 12:35 PM
RE: Oil leak - by Duncan Grimmond - 09-07-2019, 12:43 PM
RE: Oil leak - by Steve Jones - 09-07-2019, 12:53 PM
RE: Oil leak - by Duncan Grimmond - 09-07-2019, 08:34 PM
RE: Oil leak - by Hedd_Jones - 09-07-2019, 08:55 PM
RE: Oil leak - by AustinWood - 09-07-2019, 10:12 PM
