Crown Wheel Run-Out
Chris,
The “bend” as you called it, was what I was trying to eliminate, I blued the two faces together and had a good result.
I then attempted to fit the bolts! The holes did not line up.
Using smaller diameter bolts the crown wheel ran true.
So what do I do with the holes? Attempting to force the bolts in will take me back to square one I guess!
Can I ream them out but what bolts do I then use.
Does this also mean that the six planet gears are also misaligned.
The exterior of this carrier is not as visibly damaged as my original one, which had serious scars on it.
Roger
Crown Wheel Run-Out - by Chris KC - 22-06-2019, 04:01 PM
RE: Crown Wheel Run-Out - by Alan - 22-06-2019, 04:20 PM
RE: Crown Wheel Run-Out - by Howard Wright - 22-06-2019, 04:26 PM
RE: Crown Wheel Run-Out - by Chris KC - 22-06-2019, 05:19 PM
RE: Crown Wheel Run-Out - by Alan - 22-06-2019, 05:47 PM
RE: Crown Wheel Run-Out - by Bob Culver - 23-06-2019, 04:23 AM
RE: Crown Wheel Run-Out - by Stuart Giles - 23-06-2019, 08:57 AM
RE: Crown Wheel Run-Out - by scrooge - 01-07-2019, 05:48 PM
RE: Crown Wheel Run-Out - by Roger - 07-07-2019, 10:08 PM
RE: Crown Wheel Run-Out - by Chris KC - 07-07-2019, 10:22 PM
RE: Crown Wheel Run-Out - by Bob Culver - 08-07-2019, 06:08 AM
RE: Crown Wheel Run-Out - by Roger - 08-07-2019, 08:45 AM
RE: Crown Wheel Run-Out - by Chris KC - 08-07-2019, 12:18 PM
RE: Crown Wheel Run-Out - by Roger - 08-07-2019, 04:06 PM
RE: Crown Wheel Run-Out - by Chris KC - 08-07-2019, 04:50 PM
RE: Crown Wheel Run-Out - by scrooge - 08-07-2019, 08:06 PM
RE: Crown Wheel Run-Out - by Roger - 09-07-2019, 10:23 PM
RE: Crown Wheel Run-Out - by Chris KC - 09-07-2019, 10:49 PM
