Crown Wheel Run-Out
Hi KC
.004 is not very much. If the mounting pedestals are marked and measured with a mike or vernier callipers for thickness it should not be difficult to reduce one .003 progressively reducing for those each side. Could press with thumb on  a very fine flat file and/or sharpen an old file to a smooth dead square end for use as a scraper. Check with blue. Seating must not rock. Hopefully will all be OK on first assembly.
If the cw runs out radially a bit more tricky.
CW mounting bolts need to be consistently tightened.
And Roger, what is the lathe with the double raised v bed please? Hopefully not a diabolical Indian peasant made file finished Metro as mine.
Crown Wheel Run-Out - by Chris KC - 22-06-2019, 04:01 PM
RE: Crown Wheel Run-Out - by Alan - 22-06-2019, 04:20 PM
RE: Crown Wheel Run-Out - by Howard Wright - 22-06-2019, 04:26 PM
RE: Crown Wheel Run-Out - by Chris KC - 22-06-2019, 05:19 PM
RE: Crown Wheel Run-Out - by Alan - 22-06-2019, 05:47 PM
RE: Crown Wheel Run-Out - by Bob Culver - 23-06-2019, 04:23 AM
RE: Crown Wheel Run-Out - by Stuart Giles - 23-06-2019, 08:57 AM
RE: Crown Wheel Run-Out - by scrooge - 01-07-2019, 05:48 PM
RE: Crown Wheel Run-Out - by Roger - 07-07-2019, 10:08 PM
RE: Crown Wheel Run-Out - by Chris KC - 07-07-2019, 10:22 PM
RE: Crown Wheel Run-Out - by Bob Culver - 08-07-2019, 06:08 AM
RE: Crown Wheel Run-Out - by Roger - 08-07-2019, 08:45 AM
RE: Crown Wheel Run-Out - by Chris KC - 08-07-2019, 12:18 PM
RE: Crown Wheel Run-Out - by Roger - 08-07-2019, 04:06 PM
RE: Crown Wheel Run-Out - by Chris KC - 08-07-2019, 04:50 PM
RE: Crown Wheel Run-Out - by scrooge - 08-07-2019, 08:06 PM
RE: Crown Wheel Run-Out - by Roger - 09-07-2019, 10:23 PM
RE: Crown Wheel Run-Out - by Chris KC - 09-07-2019, 10:49 PM
