02-11-2017, 11:13 PM
(This post was last modified: 02-11-2017, 11:14 PM by Stuart Giles.)
(02-11-2017, 08:49 PM)Ruairidh Dunford Wrote: Actually I am not so sure that the Whitworth form is incorrect Alastair, standard threads for 5/8" BSF is 14tpi - the special Admiralty threads are 16tpi - so on second thoughts you may have found the correct one.
5/8" 16tpi is correct. Somebody else will be able to confirm but I do remember that in the past new halfshaft nuts were being sold that were a very tight fit and it turned out they had been cut incorrectly so do get some confirmation on this before proceeding
Halfshafts are 5/8 x 16 TPI Whitworth Form sometimes called Whitworth Fine; anyway, the thread angle is 55 degrees -AFAIK so are pretty well all British threads except Cycle (60 degrees) and BA (47.5 degrees IIRC). The Admiralty threads are effectively the same as Whitworth Form. Admiralty threads get a mention here.
http://www.gerardsgarage.com/supportfile...Tables.pdf
There's comprehensive information regarding a vast variety of thread systems on this site.
http://www.gewinde-normen.de/en/index.html
BTW, some while ago, I bought some of those halfshaft nuts mentioned by Ruairidh which wouldn't screw onto a halfshaft; was difficult to know if they were slightly undersize, or whether they had been made with a 5/8 x 16 UNS thread
