Banjo axle 1928. rear pinion bearings
Thanks Tony.
I think I may be worrying about a very unlikely event.
I have spotted that the RHP MRJA 7/8" bearing my dad must have fitted in the early 80's would solve the problem if it existed. They are still available , or at least I spotted the equivalent on simply bearings website but at £106 a throw, I may take a more detailed inspection of the pitting in the one I have.
Anyway, now i'm on to the fun bit, pushing the diff carrier back and forth to measure the end float with a DTI poked down the mouth of the casing which I cant see to read.  . And then onto the dreaded engineers blue.
regards
Charlie.
RE: Banjo axle 1928. rear pinion bearings - by scrooge - 21-06-2019, 05:01 PM
