Banjo axle 1928. rear pinion bearings
Bob,
The term banjo when applied to a rear axle refers to the fact that, if you look at the centre casing of a three piece axle, it is circular with a small nose sticking out, a bit like a banjo with its fingerboard.
David.
RE: Banjo axle 1928. rear pinion bearings - by David Stepney - 20-06-2019, 11:18 PM
