  • 1 Vote(s) - 3 Average
track rod tie rod steering ends
HI All,
Looking At the photo the track rod bolt is able to rotate hence the grease nipple, as the rod end only has one pivot pinĀ  Vertical.
That end of axle is welded solid so any rotational movement must be at the other end.
As Ian has said the axle must have rotational movement and usually not at the point were the track rods meet.
Colin
NZ
track rod tie rod steering ends - by a7grenade - 05-06-2019, 09:01 PM
RE: track rod tie rod steering ends - by JonE - 05-06-2019, 10:54 PM
RE: track rod tie rod steering ends - by Colin Reed - 12-06-2019, 10:02 PM
