10-06-2019, 08:46 PM
To rewind an armature for 12v requires thinner wire and as overheating of the armature is the main problem this is self defeating. (It was common to rewind troublesome armatures with a thicker gauge but which delayed cut in )
Most dynamos I have seen have commutators too worn to warrant rewire. Do the reconditioners of Seven dynamos have a source of new comms?
I have to concede that modern sealed batteries are not suited to the original Seven charging. Do not like more than about 14.4/7.2 volts. The car system kept at a low rate except at night and maintained by a modern bench charger seems more ideal.
The idea of introducing electronics to a Seven troubles me, but I suppose if operating 2 wire, if the electronic regulators can limit max 2 wire field current mainly by switching, an earlier cut in is possible than otherwise. The switched field current has an exaggerated heating effect but the fields seem very tolerant.
