Back to the extra block studs
#26
I have used a bracket on the front as it depends what cyl/head you are using, for the rear stud fixing use a short length of hexagonal nut stock bar, tap 5/16bsf one end and turn down and die a stud length on the lower end, makeup a long tensile stud and angle bracket to fit the 2 rear head studs and weld a short length of drilled nut bar to the a/bracket, sorry can't provide a photo as I am in Cumbria for Barbon hillclimb. Terry
Back to the extra block studs - by Charles P - 23-09-2017, 11:38 PM
RE: Back to the extra block studs - by Alan - 24-09-2017, 08:45 AM
RE: Back to the extra block studs - by Charles P - 24-09-2017, 09:35 AM
RE: Back to the extra block studs - by Alan - 24-09-2017, 09:59 AM
RE: Back to the extra block studs - by Charles P - 24-09-2017, 10:09 AM
RE: Back to the extra block studs - by Alan - 24-09-2017, 10:26 AM
RE: Back to the extra block studs - by dickie65 - 23-12-2017, 06:36 PM
RE: Back to the extra block studs - by Charles P - 24-12-2017, 09:09 AM
RE: Back to the extra block studs - by Charles P - 24-12-2017, 01:13 PM
RE: Back to the extra block studs - by jansens - 27-12-2017, 02:26 PM
RE: Back to the extra block studs - by Colin Reed - 26-12-2017, 11:33 PM
RE: Back to the extra block studs - by Alan - 27-12-2017, 06:17 PM
RE: Back to the extra block studs - by Charles P - 27-12-2017, 06:40 PM
RE: Back to the extra block studs - by Dirk73 - 07-06-2019, 01:23 PM
RE: Back to the extra block studs - by Terrytuned - 07-06-2019, 05:44 PM
RE: Back to the extra block studs - by Alan - 07-06-2019, 05:59 PM
RE: Back to the extra block studs - by Dave Mann - 08-06-2019, 11:31 AM
