Low diff ratio
Isn't it 5.625, 8x45 teeth ?
The Big 7 diff is different in that the 1/2 shafts are larger requiring  special bearings,(Reduced o/d I think) either side of diff to fit and boring out of the side tubes, I don't think the CWP ratio was any lower either ?
If you are running a 4 sp box you wouldn't need that low a ratio.
Low diff ratio - by Greig Smith - 04-06-2019, 10:34 AM
RE: Low diff ratio - by Mark Dymond - 04-06-2019, 10:46 AM
RE: Low diff ratio - by Greig Smith - 04-06-2019, 10:55 AM
RE: Low diff ratio - by Chris KC - 04-06-2019, 11:48 AM
RE: Low diff ratio - by JonE - 04-06-2019, 11:58 AM
RE: Low diff ratio - by Chris KC - 04-06-2019, 12:27 PM
RE: Low diff ratio - by Steve Jones - 04-06-2019, 01:10 PM
RE: Low diff ratio - by spannerman - 04-06-2019, 03:45 PM
RE: Low diff ratio - by Ruairidh Dunford - 04-06-2019, 03:50 PM
RE: Low diff ratio - by Rogerfrench - 04-06-2019, 04:50 PM
RE: Low diff ratio - by Austin in the Shed - 04-06-2019, 05:18 PM
RE: Low diff ratio - by Steve Jones - 04-06-2019, 05:22 PM
RE: Low diff ratio - by Greig Smith - 04-06-2019, 05:48 PM
