Low diff ratio
I asked a very similar question a while back Jon!
You need the right pinion, the tooth shape is different.
(That is to say, you could only use a pinion from another 8/45 pair.
Ideally you don't mix and match parts from different pairs, but they will work - the main probable downside being noise).
Low diff ratio - by Greig Smith - 04-06-2019, 10:34 AM
RE: Low diff ratio - by Mark Dymond - 04-06-2019, 10:46 AM
RE: Low diff ratio - by Greig Smith - 04-06-2019, 10:55 AM
RE: Low diff ratio - by Chris KC - 04-06-2019, 11:48 AM
RE: Low diff ratio - by JonE - 04-06-2019, 11:58 AM
RE: Low diff ratio - by Chris KC - 04-06-2019, 12:27 PM
RE: Low diff ratio - by Steve Jones - 04-06-2019, 01:10 PM
RE: Low diff ratio - by spannerman - 04-06-2019, 03:45 PM
RE: Low diff ratio - by Ruairidh Dunford - 04-06-2019, 03:50 PM
RE: Low diff ratio - by Rogerfrench - 04-06-2019, 04:50 PM
RE: Low diff ratio - by Austin in the Shed - 04-06-2019, 05:18 PM
RE: Low diff ratio - by Steve Jones - 04-06-2019, 05:22 PM
RE: Low diff ratio - by Greig Smith - 04-06-2019, 05:48 PM
