Nose cone oil leak
Hi David
I intend someday to rebuild the nose cone on my RK but in the meantime I fitted a small brass angle under the radiator (using the radiator mounting bolt). You can swing it back to use the starting handle.
It doesn't stop the leak although if the starter shaft has the correct felt washer it should!  (mine doesn't have the washer but doesn't leak too much).
Nose cone oil leak - by David.H - 29-05-2019, 03:36 PM
RE: Nose cone oil leak - by Reckless Rat - 29-05-2019, 05:07 PM
RE: Nose cone oil leak - by Howard Wright - 29-05-2019, 06:08 PM
RE: Nose cone oil leak - by Douglas Alderson - 29-05-2019, 06:23 PM
RE: Nose cone oil leak - by Austin in the Shed - 30-05-2019, 10:58 PM
