  • 1 Vote(s) - 3 Average
1932 RP Battery Box
Good morning.
I measured a battery box yesterday when I visited Oxfordshire Sevens.
They are actually closed for the rest of week and open again on the 4th June. I was lucky that they were in.
The opening is 153mm by 190mm. There is a flange around the top to support the box when it is dropped into the hole in the floor. There are two depths of boxes. The standard box is 175mm deep, but they do a deeper version at 195mm. The deeper version is to accommodate modern batteries, some of which are apparently taller than older designs. They did say that they will adjust the sizes to suit your measurements, if you wish.
The boxes are supplied fully assembled, ready to fit. However, they can be provided in parts, if preferred. On the car which I saw there, the fully assembled box would just drop straight in.
I hope that this helps.
Regards,
Jamie.
1932 RP Battery Box - by Smiley - 24-05-2019, 08:02 PM
RE: 1932 RP Battery Box - by Ian M - 24-05-2019, 09:00 PM
RE: 1932 RP Battery Box - by Hedd_Jones - 26-05-2019, 05:10 PM
RE: 1932 RP Battery Box - by Smiley - 26-05-2019, 08:10 PM
RE: 1932 RP Battery Box - by Hedd_Jones - 26-05-2019, 08:36 PM
RE: 1932 RP Battery Box - by Smiley - 26-05-2019, 09:58 PM
RE: 1932 RP Battery Box - by Hedd_Jones - 26-05-2019, 10:33 PM
RE: 1932 RP Battery Box - by jonblob33 - 27-05-2019, 08:24 PM
RE: 1932 RP Battery Box - by Smiley - 27-05-2019, 08:50 PM
RE: 1932 RP Battery Box - by Jamie - 27-05-2019, 09:25 PM
RE: 1932 RP Battery Box - by Smiley - 27-05-2019, 09:50 PM
RE: 1932 RP Battery Box - by Jamie - 27-05-2019, 10:27 PM
RE: 1932 RP Battery Box - by Jamie - 29-05-2019, 07:12 AM
RE: 1932 RP Battery Box - by Smiley - 29-05-2019, 09:13 AM
RE: 1932 RP Battery Box - by Ian M - 29-05-2019, 10:13 AM
RE: 1932 RP Battery Box - by Jamie - 29-05-2019, 12:09 PM
RE: 1932 RP Battery Box - by Smiley - 29-05-2019, 09:40 PM
RE: 1932 RP Battery Box - by Bill Sheehan - 31-05-2019, 01:11 AM
RE: 1932 RP Battery Box - by David.H - 31-05-2019, 08:37 AM
RE: 1932 RP Battery Box - by Smiley - 31-05-2019, 04:17 PM
