27-05-2019, 11:43 AM
(This post was last modified: 27-05-2019, 12:14 PM by Peter Sweeney.)
Depends what you are using the conversion for. If its a special This is the conversion I made in the 80's using a mini alternator. I had a friend who turned a v belt pulley for the camshaft in Ali and a steel shaft to use the original dynamo end plates without the commutator. Then turned the fan casting through 180 degrees. It was a broken one so I could file the remains of the fan hole off. The bracket for the alternator is bolted to the fan casting. It has worked without problems ever since. The mini alternator dose not need a cut out as its built in. I have converted my big 7 in the same way the cut out is now only used as a junction box. Now I can blind Range rovers back!!
Photos
Photos
Photos
Photos
Sorry finger trouble
Sorry I am trying to post a photo but they seem to be too large to be accepted. Will try another
Better photo
Photos
Photos
