26-05-2019, 05:01 PM
The track rod ends are threaded onto the end of the rod so that (in theory) if you free one end and loosen the pinch bolt you should be able to screw the ends in or out to adjust toe-in. If it's not been disturbed in a while expect each and every part to put up a fight. I'd start by drowning the ends in plus gas and sleeping on it.
