Exhaust "popping" on overrun?
#25
Funnily enough only yesterday I adapted a later action plate marked 17 degrees - I agree an insert would have been a nice solution, and I did consider sleeving the pins instead of altering the hole; but it responded fairly well to a dab of MIG on the outboard sides of the holes, which was then ground flush and gently filed to give the desired amount of advance; in my case I settledĀ on 8.5 degrees and got it more or less by sheer luck at first attempt. I used a DTI on the rotor arm to double-check the actual amount of advance.
One observation I would add is that I have stripped a number of DK4A's which have at some time been re-bushed; but have yet to find one where the oil supply hole had been re-drilled through the new bush!
Exhaust "popping" on overrun? - by Joe eck - 07-05-2019, 06:48 PM
RE: Exhaust "popping" on overrun? - by Joe eck - 07-05-2019, 07:15 PM
RE: Exhaust "popping" on overrun? - by Hedd_Jones - 07-05-2019, 07:25 PM
RE: Exhaust "popping" on overrun? - by Hedd_Jones - 07-05-2019, 10:44 PM
RE: Exhaust "popping" on overrun? - by Hedd_Jones - 08-05-2019, 02:45 PM
RE: Exhaust "popping" on overrun? - by Joe eck - 08-05-2019, 07:12 PM
RE: Exhaust "popping" on overrun? - by Joe eck - 08-05-2019, 07:35 PM
RE: Exhaust "popping" on overrun? - by Hedd_Jones - 08-05-2019, 08:00 PM
RE: Exhaust "popping" on overrun? - by Bob Culver - 08-05-2019, 09:46 PM
RE: Exhaust "popping" on overrun? - by Joe eck - 12-05-2019, 07:38 PM
RE: Exhaust "popping" on overrun? - by Colin Reed - 12-05-2019, 09:26 PM
RE: Exhaust "popping" on overrun? - by Joe eck - 13-05-2019, 06:51 PM
RE: Exhaust "popping" on overrun? - by Chris KC - 13-05-2019, 07:16 PM
RE: Exhaust "popping" on overrun? - by Chris KC - 13-05-2019, 09:07 PM
