Steering caster
Suggest you measure your existing castor before you do anything else. Then you know what you may be trying to achieve by way of angle and that both sides are the same. The chassis has built in castor in the design. Factory drawings showing datum points
/castor have been on this forum before as this is far from being a new topic.
Also you say you have a two seater, if the rear springs have been set with less camber you may already have more castor than standard.
Worth checking out the whole picture first I think.
Paul N-M
Steering caster - by jonblob33 - 13-05-2019, 05:08 PM
RE: Steering caster - by Bruce Nicholls - 13-05-2019, 05:33 PM
RE: Steering caster - by Paul N-M - 13-05-2019, 05:48 PM
RE: Steering caster - by Charles Levien - 13-05-2019, 06:00 PM
