12-05-2019, 04:56 PM
Is the ammeter broken now ?? If current can't pass through the ammeter, then you won't get anything except the starter to work. You have 2 different circuits that are "Broken" Ignition and Lights, the first is via the ignition switch and the other is independant of the ignition and is controlled by the light switch (Allbeit its the same switch cluster on a Ruby).
