Petrol tank repair
Roland & Dave, sure, use the photos. I hope they serve as a warning.
My technique for soldering a pinhole or patch (using a gas-fired iron) has been to run a vacuum cleaner hose from a running engine exhaust pipe into the filler tube. Lots of carbon monoxide/carbon dioxide/water vapour to expel any oxygen and if there is no oxygen there cannot be any combustion. A good wash out with soapy water, dry, then diesel or paraffin to remove flux residues and check for leaks.
Most fittings like fillers,drains,gauge mounts and breathers seem to be fitted and sealed by soldering and I think it's best to avoid over-heating with an oxy-acetylene flame.
Petrol tank repair - by Duncan Grimmond - 10-05-2019, 06:22 PM
RE: Petrol tank repair - by Chris KC - 10-05-2019, 06:59 PM
RE: Petrol tank repair - by Stuart Giles - 11-05-2019, 11:15 AM
RE: Petrol tank repair - by andrew34ruby - 11-05-2019, 12:04 PM
RE: Petrol tank repair - by Dave Mann - 11-05-2019, 05:50 PM
RE: Petrol tank repair - by Roland Alcock - 11-05-2019, 08:38 PM
RE: Petrol tank repair - by Alan - 11-05-2019, 09:56 PM
RE: Petrol tank repair - by Duncan Grimmond - 12-05-2019, 12:23 AM
RE: Petrol tank repair - by Dave Mann - 12-05-2019, 09:43 AM
RE: Petrol tank repair - by Roland Alcock - 12-05-2019, 03:15 PM
RE: Petrol tank repair - by Erich - 13-05-2019, 05:08 PM
