  • 1 Vote(s) - 5 Average
Front hub removal separation
(26-10-2017, 05:33 PM)Derek Sheldon Wrote: Pne has to ask, how the hell you got the split pin out to remove the retaining nut. Put it back on and do the nut up. Get the correct puller from cherished suppliers , remove the outer,remove nut, put outer back on do up wheel nuts , use puller to remove whole assembly. Should have removed the three c/s set screws from the outset.
The split pin came out easily through the hole in the stub axle. I removed the 3 csk screws to get the drum off.
I'm now asking a very daft question....if having taken the outer hub off, assuming it comes off easily, presumably you mean knock the front bearing out first, then put it back on and do the wheel nuts up...is this right?
This is a late Ruby front axle.
Arthur
Front hub removal separation - by merlinart - 26-10-2017, 05:25 PM
RE: Front hub removal separation - by merlinart - 26-10-2017, 05:47 PM
RE: Front hub removal separation - by Charles P - 26-10-2017, 06:22 PM
RE: Front hub removal separation - by Alan - 26-10-2017, 06:40 PM
RE: Front hub removal separation - by merlinart - 26-10-2017, 06:57 PM
RE: Front hub removal separation - by Steve Jones - 26-10-2017, 07:14 PM
RE: Front hub removal separation - by merlinart - 26-10-2017, 07:32 PM
RE: Front hub removal separation - by JonE - 20-05-2020, 09:38 PM
RE: Front hub removal separation - by JonE - 20-05-2020, 10:39 PM
RE: Front hub removal separation - by spannerman - 21-05-2020, 07:37 PM
RE: Front hub removal separation - by JonE - 21-05-2020, 09:12 PM
RE: Front hub removal separation - by Bob Culver - 22-05-2020, 01:00 AM
RE: Front hub removal separation - by JonE - 22-05-2020, 07:41 AM
RE: Front hub removal separation - by Bob Culver - 22-05-2020, 10:01 AM
RE: Front hub removal separation - by JonE - 22-05-2020, 08:56 PM
RE: Front hub removal separation - by Bob Culver - 22-05-2020, 11:39 PM
RE: Front hub removal separation - by JonE - 23-05-2020, 07:16 AM
RE: Front hub removal separation - by John Mason - 23-05-2020, 04:59 PM
