09-05-2019, 01:15 PM
Sure enough the 180 degree rotation of the brush base plate
has solved the problem. Not much sparking at the commentator
either.
The pinion gear dutifully progresses along the spiral
Cut shaft towards the ring gear on the flywheel when power is
applied.
I’ll also try and make sure the small spring loaded pin
, which stops the pinion going awol is working before
Finally fitting onto the crankcase.
This is all good news as once the starter is installed I can finalise
the flooring, the petrol tank, petrol line, and under dash wiring.
Many thanks to all who contributed to this thread, adding a little to
The community Database that A7 Friends Forum represents.
Now to try and sort out the Dynamo!!
Regards
Bill G
either.
applied.
Regards
Bill G
