Time to go 12volt?
(26-10-2017, 10:11 AM)Ruairidh Dunford Wrote: I will report back on the use of the 6v alternator, once I have fitted it
Well, it fits perfectly.
The threads into the housing end are 1/4 BSW as apposed to 1/4 BSF but changing the bolts was not an issue. The thread into the top for the distributor clamp is 1/4 bsf as apposed to 1/4 bsw but this again was simply rectified by swapping a bolt over.
It is incredibly quiet, very easy to wire up and immediately produced 16amps of charge - I need to take it on a long run to see what happens when the battery reaches fully charged but I am expecting it to either reduce the charge or show no charge. I am also interested to see how long it takes to bring the battery back up to charge.
The cut-out is effectively redundant, to do this you must remove the green wires from F2 and place them into A. The Yellow wire remains in the D terminal as before.
I have suggested a few aesthetically pleasing changes (paint everything black, replace cross-head screws with slot etc. and, although I was not sure about the connection block initially, it does not stand out once fitted) which should make it quite unobtrusive. Time will tell if it proves reliable but I am informed that the technology inside is already proven over a long period.
I asked about making a similar one for the mag. engine and they have promised to think on that, depending how this model sells.
I have all my own cars currently running fine on properly rebuilt dynamos that work very well but this one seems a very sensible alternative, and certainly comparative on pricing - if you need one!
I will continue to report back after use...
Time to go 12volt? - by Stuart Joseph - 24-10-2017, 08:17 PM
RE: Time to go 12volt? - by Ruairidh Dunford - 24-10-2017, 08:23 PM
RE: Time to go 12volt? - by Nick Turley - 24-10-2017, 09:59 PM
RE: Time to go 12volt? - by Dave Mann - 25-10-2017, 08:18 PM
RE: Time to go 12volt? - by Derek Sheldon - 25-10-2017, 10:21 PM
RE: Time to go 12volt? - by Ian Williams - 25-10-2017, 10:56 PM
RE: Time to go 12volt? - by Tony Press - 25-10-2017, 11:46 PM
RE: Time to go 12volt? - by GK5268 - 25-10-2017, 11:09 PM
RE: Time to go 12volt? - by Roland Alcock - 26-10-2017, 12:05 AM
RE: Time to go 12volt? - by Ian Williams - 26-10-2017, 12:37 AM
RE: Time to go 12volt? - by andrew34ruby - 26-10-2017, 09:23 AM
RE: Time to go 12volt? - by Charles Levien - 26-10-2017, 09:26 AM
RE: Time to go 12volt? - by Ruairidh Dunford - 26-10-2017, 10:11 AM
RE: Time to go 12volt? - by AustinWood - 26-10-2017, 10:15 AM
RE: Time to go 12volt? - by Ruairidh Dunford - 26-10-2017, 10:21 AM
RE: Time to go 12volt? - by Chris KC - 26-10-2017, 10:36 AM
RE: Time to go 12volt? - by Stuart Joseph - 26-10-2017, 01:20 PM
RE: Time to go 12volt? - by Ruairidh Dunford - 26-10-2017, 02:38 PM
RE: Time to go 12volt? - by Nick Turley - 28-10-2017, 08:45 PM
RE: Time to go 12volt? - by Derek Sheldon - 27-10-2017, 07:01 PM
RE: Time to go 12volt? - by Hedd Jones - 28-10-2017, 10:30 AM
RE: Time to go 12volt? - by DavidL - 27-04-2018, 12:16 PM
RE: Time to go 12volt? - by Erich - 27-04-2018, 06:17 PM
RE: Time to go 12volt? - by DavidL - 27-04-2018, 06:58 PM
RE: Time to go 12volt? - by Charles P - 28-04-2018, 09:42 AM
RE: Time to go 12volt? - by Ruairidh Dunford - 28-04-2018, 10:02 AM
RE: Time to go 12volt? - by Hugh Sammons - 28-04-2018, 07:13 PM
RE: Time to go 12volt? - by JonE - 28-04-2018, 01:54 PM
RE: Time to go 12volt? - by Ruairidh Dunford - 28-04-2018, 03:48 PM
RE: Time to go 12volt? - by Ruairidh Dunford - 28-04-2018, 07:35 PM
RE: Time to go 12volt? - by Hugh Sammons - 28-04-2018, 08:01 PM
