07-05-2019, 07:44 AM
That's a new one on me. If the ignition is too far advanced peak cylinder pressure occurs before TDC then there's an almighty stress put on the gasket as well as everything else in the engine. Far more likely though the 'bridge' between the cylinders is corroded, overheating has occurred, or the joint face is not flat, in my 'umble opinion.
