  • 5 Vote(s) - 2.6 Average
All Alloy Cup progress
.jpeg   B6AFE1CA-E8B6-49E7-BCED-597118603BE3.jpeg (Size: 104.48 KB / Downloads: 365)
.jpeg   5DAC53CE-440B-4A1E-9FE5-3E773582C1F6.jpeg (Size: 80.62 KB / Downloads: 363)
Back on the Cup case....
Neil came over this afternoon to measure up some
Radiator dimensions for one he is getting made.
In the morning I made the last visible alloy panel
to sit atop the petrol tank. Standard method , paper template,
Transfer to plywood former, cut alloy panel oversize, form flange
with a selection of hammers. This panel with be held in position
By the wooden bonnet rest and wrap nicely round the tank
With rubber profile neatly finishing the bottom edge.
Charged up the new 6v battery and proved that the bacon slicer
looks a goer after cleaning the switch contacts.
In between times lacquered the new alloy panel and finish painted
The petrol tank after first putting in a pint of white spirit and some rough stones
And agitated for about 10 minutes, getting a fair amount of rust dust out
But second flush out pretty clear.
No leaks either!!! So tank can now be finally fitted, once the starter motor is installed
as access much easier without the tank in position.
I had previously dismantled and also cleaned the dynamo internals and fitted new brushes and thought
if I put 6v + on one terminal and earthed the casing it would spin( fast?)
but no, it barely turned.
This dynamo has the shunt resistance wires in a small housing on the casing.
My control panel has the summer winter charge settings and I think this dyno is
Compatible ?
Can’t figure out if this dynamo is OK but don’t otherwise
Know how to get it tested?  Any suggestions gratefully received.
Plenty still to do.......
Regards
Bill G
Aka AllAlloyCup
All Alloy Cup progress - by AllAlloyCup - 08-08-2017, 12:01 PM
RE: GE Cup progress - by Timothy P - 09-04-2019, 10:36 AM
RE: GE Cup progress - by AllAlloyCup - 09-04-2019, 02:05 PM
RE: All Alloy Cup progress - by Timothy P - 09-04-2019, 02:22 PM
RE: All Alloy Cup progress - by AllAlloyCup - 12-04-2019, 02:40 PM
RE: All Alloy Cup progress - by Mike Costigan - 12-04-2019, 07:02 PM
RE: All Alloy Cup progress - by AllAlloyCup - 12-04-2019, 07:27 PM
RE: All Alloy Cup progress - by Steve Jones - 12-04-2019, 07:38 PM
RE: All Alloy Cup progress - by Alan - 12-04-2019, 08:14 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 12-04-2019, 08:38 PM
RE: All Alloy Cup progress - by AllAlloyCup - 12-04-2019, 08:47 PM
RE: All Alloy Cup progress - by AllAlloyCup - 14-04-2019, 02:04 PM
RE: All Alloy Cup progress - by David Stepney - 14-04-2019, 02:12 PM
RE: All Alloy Cup progress - by AllAlloyCup - 14-04-2019, 02:28 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 14-04-2019, 06:58 PM
RE: All Alloy Cup progress - by AllAlloyCup - 14-04-2019, 07:13 PM
RE: All Alloy Cup progress - by AustinWood - 15-04-2019, 01:39 PM
RE: All Alloy Cup progress - by AllAlloyCup - 19-04-2019, 02:27 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 20-04-2019, 07:53 AM
RE: All Alloy Cup progress - by AllAlloyCup - 24-04-2019, 09:53 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 24-04-2019, 06:11 PM
RE: All Alloy Cup progress - by Chris KC - 24-04-2019, 06:32 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-04-2019, 08:07 PM
RE: All Alloy Cup progress - by AllAlloyCup - 25-04-2019, 10:53 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 25-04-2019, 11:45 AM
RE: All Alloy Cup progress - by AllAlloyCup - 25-04-2019, 12:55 PM
RE: All Alloy Cup progress - by JonE - 25-04-2019, 05:08 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 25-04-2019, 05:14 PM
RE: All Alloy Cup progress - by AllAlloyCup - 25-04-2019, 07:16 PM
RE: All Alloy Cup progress - by David Stepney - 25-04-2019, 08:01 PM
RE: All Alloy Cup progress - by AllAlloyCup - 25-04-2019, 08:43 PM
RE: All Alloy Cup progress - by David Stepney - 25-04-2019, 09:42 PM
RE: All Alloy Cup progress - by Tony Press - 25-04-2019, 11:00 PM
RE: All Alloy Cup progress - by AllAlloyCup - 26-04-2019, 03:54 PM
RE: All Alloy Cup progress - by David Stepney - 26-04-2019, 08:02 PM
RE: All Alloy Cup progress - by AllAlloyCup - 04-05-2019, 09:35 PM
RE: All Alloy Cup progress - by David.H - 05-05-2019, 01:59 PM
RE: All Alloy Cup progress - by AllAlloyCup - 05-05-2019, 02:20 PM
RE: All Alloy Cup progress - by Tom Coates - 06-05-2019, 12:30 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 06-05-2019, 01:42 PM
RE: All Alloy Cup progress - by AllAlloyCup - 06-05-2019, 05:33 PM
RE: All Alloy Cup progress - by Ian Williams - 06-05-2019, 08:34 PM
RE: All Alloy Cup progress - by AllAlloyCup - 06-05-2019, 08:48 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 06-05-2019, 08:56 PM
RE: All Alloy Cup progress - by Tom Coates - 07-05-2019, 09:39 AM
RE: All Alloy Cup progress - by Malcolm Parker - 07-05-2019, 11:17 AM
RE: All Alloy Cup progress - by Charles P - 07-05-2019, 11:50 AM
RE: All Alloy Cup progress - by AllAlloyCup - 07-05-2019, 12:47 PM
RE: All Alloy Cup progress - by AllAlloyCup - 10-05-2019, 08:27 PM
RE: All Alloy Cup progress - by AllAlloyCup - 14-05-2019, 07:27 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 14-05-2019, 08:15 PM
RE: All Alloy Cup progress - by AllAlloyCup - 14-05-2019, 08:22 PM
RE: All Alloy Cup progress - by AllAlloyCup - 16-05-2019, 09:08 PM
RE: All Alloy Cup progress - by AllAlloyCup - 20-05-2019, 09:06 PM
RE: All Alloy Cup progress - by Mike Costigan - 20-05-2019, 09:11 PM
RE: All Alloy Cup progress - by AllAlloyCup - 21-05-2019, 05:26 PM
RE: All Alloy Cup progress - by JonE - 21-05-2019, 06:59 PM
RE: All Alloy Cup progress - by Mark R - 21-05-2019, 10:50 PM
RE: All Alloy Cup progress - by AllAlloyCup - 22-05-2019, 06:31 AM
RE: All Alloy Cup progress - by AllAlloyCup - 22-05-2019, 06:33 PM
RE: All Alloy Cup progress - by David Stepney - 22-05-2019, 06:53 PM
RE: All Alloy Cup progress - by AllAlloyCup - 23-05-2019, 02:16 PM
RE: All Alloy Cup progress - by AllAlloyCup - 23-05-2019, 05:35 PM
RE: All Alloy Cup progress - by Austin Carr - 24-05-2019, 11:50 AM
RE: All Alloy Cup progress - by Ian Williams - 25-05-2019, 09:06 AM
RE: All Alloy Cup progress - by AllAlloyCup - 25-05-2019, 09:23 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 25-05-2019, 09:35 AM
RE: All Alloy Cup progress - by AllAlloyCup - 25-05-2019, 10:06 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 25-05-2019, 12:19 PM
RE: All Alloy Cup progress - by AllAlloyCup - 25-05-2019, 01:42 PM
RE: All Alloy Cup progress - by AllAlloyCup - 28-05-2019, 05:27 PM
RE: All Alloy Cup progress - by Mike Costigan - 28-05-2019, 06:09 PM
RE: All Alloy Cup progress - by AllAlloyCup - 30-05-2019, 01:46 PM
RE: All Alloy Cup progress - by Chris KC - 30-05-2019, 02:21 PM
RE: All Alloy Cup progress - by AllAlloyCup - 30-05-2019, 03:22 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-06-2019, 02:31 PM
RE: All Alloy Cup progress - by Mike Costigan - 02-06-2019, 02:53 PM
RE: All Alloy Cup progress - by David Stepney - 02-06-2019, 04:24 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-06-2019, 04:40 PM
RE: All Alloy Cup progress - by Mike Costigan - 02-06-2019, 05:35 PM
RE: All Alloy Cup progress - by JonE - 02-06-2019, 05:38 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-06-2019, 05:50 PM
RE: All Alloy Cup progress - by David Stepney - 02-06-2019, 06:22 PM
RE: All Alloy Cup progress - by Mike Costigan - 02-06-2019, 06:44 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 02-06-2019, 07:31 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-06-2019, 07:51 PM
RE: All Alloy Cup progress - by David Stepney - 02-06-2019, 08:10 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-06-2019, 10:32 PM
RE: All Alloy Cup progress - by David Stepney - 02-06-2019, 11:06 PM
RE: All Alloy Cup progress - by Mike Costigan - 03-06-2019, 08:26 AM
RE: All Alloy Cup progress - by Charles Levien - 03-06-2019, 08:51 AM
RE: All Alloy Cup progress - by Chris KC - 03-06-2019, 08:57 AM
RE: All Alloy Cup progress - by AllAlloyCup - 03-06-2019, 10:12 AM
RE: All Alloy Cup progress - by AllAlloyCup - 03-06-2019, 11:10 PM
RE: All Alloy Cup progress - by Mike Costigan - 04-06-2019, 08:57 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 04-06-2019, 11:54 AM
RE: All Alloy Cup progress - by AllAlloyCup - 04-06-2019, 12:42 PM
RE: All Alloy Cup progress - by Chris Garner - 04-06-2019, 01:52 PM
RE: All Alloy Cup progress - by AllAlloyCup - 04-06-2019, 02:43 PM
RE: All Alloy Cup progress - by Mike Costigan - 04-06-2019, 02:51 PM
RE: All Alloy Cup progress - by AllAlloyCup - 04-06-2019, 02:56 PM
RE: All Alloy Cup progress - by Hedd_Jones - 04-06-2019, 02:57 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 04-06-2019, 03:03 PM
RE: All Alloy Cup progress - by AllAlloyCup - 04-06-2019, 03:26 PM
RE: All Alloy Cup progress - by Hedd_Jones - 04-06-2019, 03:57 PM
RE: All Alloy Cup progress - by AllAlloyCup - 04-06-2019, 04:04 PM
RE: All Alloy Cup progress - by AllAlloyCup - 06-06-2019, 04:39 PM
RE: All Alloy Cup progress - by JonE - 06-06-2019, 07:38 PM
RE: All Alloy Cup progress - by AllAlloyCup - 06-06-2019, 08:02 PM
RE: All Alloy Cup progress - by AllAlloyCup - 06-06-2019, 10:09 PM
RE: All Alloy Cup progress - by AllAlloyCup - 07-06-2019, 10:46 AM
RE: All Alloy Cup progress - by JonE - 07-06-2019, 12:13 PM
RE: All Alloy Cup progress - by AllAlloyCup - 12-06-2019, 08:55 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 12-06-2019, 09:03 PM
RE: All Alloy Cup progress - by Zetomagneto - 13-06-2019, 08:20 AM
RE: All Alloy Cup progress - by John Mason - 13-06-2019, 09:49 AM
RE: All Alloy Cup progress - by AllAlloyCup - 13-06-2019, 10:05 AM
RE: All Alloy Cup progress - by AllAlloyCup - 14-06-2019, 09:42 PM
RE: All Alloy Cup progress - by AllAlloyCup - 15-06-2019, 08:17 AM
RE: All Alloy Cup progress - by Malcolm Parker - 15-06-2019, 11:18 AM
RE: All Alloy Cup progress - by Steve Jones - 15-06-2019, 02:50 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 15-06-2019, 03:09 PM
RE: All Alloy Cup progress - by Howard Wright - 15-06-2019, 05:17 PM
RE: All Alloy Cup progress - by AllAlloyCup - 15-06-2019, 05:38 PM
RE: All Alloy Cup progress - by Malcolm Parker - 16-06-2019, 09:12 AM
RE: All Alloy Cup progress - by AllAlloyCup - 16-06-2019, 12:20 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 16-06-2019, 12:31 PM
RE: All Alloy Cup progress - by AllAlloyCup - 16-06-2019, 02:20 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 16-06-2019, 09:17 PM
RE: All Alloy Cup progress - by AllAlloyCup - 17-06-2019, 08:35 PM
RE: All Alloy Cup progress - by Peter Naulls - 17-06-2019, 08:39 PM
RE: All Alloy Cup progress - by David Stepney - 17-06-2019, 08:50 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 17-06-2019, 09:00 PM
RE: All Alloy Cup progress - by Howard Wright - 17-06-2019, 09:05 PM
RE: All Alloy Cup progress - by AllAlloyCup - 17-06-2019, 09:05 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 17-06-2019, 09:19 PM
RE: All Alloy Cup progress - by Ian Williams - 17-06-2019, 09:50 PM
RE: All Alloy Cup progress - by AllAlloyCup - 17-06-2019, 10:03 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 18-06-2019, 09:39 AM
RE: All Alloy Cup progress - by Malcolm Parker - 18-06-2019, 12:49 PM
RE: All Alloy Cup progress - by Steve Jones - 18-06-2019, 01:33 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 18-06-2019, 06:05 PM
RE: All Alloy Cup progress - by AllAlloyCup - 01-07-2019, 10:13 AM
RE: All Alloy Cup progress - by AllAlloyCup - 01-07-2019, 07:30 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 01-07-2019, 08:53 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 01-07-2019, 09:01 PM
RE: All Alloy Cup progress - by Ashleyvincent - 01-07-2019, 09:20 PM
RE: All Alloy Cup progress - by David Stepney - 01-07-2019, 09:50 PM
RE: All Alloy Cup progress - by AllAlloyCup - 01-07-2019, 11:19 PM
RE: All Alloy Cup progress - by Haggis - 02-07-2019, 03:50 PM
RE: All Alloy Cup progress - by Malcolm Parker - 02-07-2019, 04:00 PM
RE: All Alloy Cup progress - by Haggis - 02-07-2019, 04:27 PM
RE: All Alloy Cup progress - by AllAlloyCup - 03-07-2019, 09:52 PM
RE: All Alloy Cup progress - by AllAlloyCup - 05-07-2019, 02:49 PM
RE: All Alloy Cup progress - by AllAlloyCup - 10-07-2019, 10:54 AM
RE: All Alloy Cup progress - by AllAlloyCup - 13-07-2019, 05:58 PM
RE: All Alloy Cup progress - by Austin Carr - 13-07-2019, 07:08 PM
RE: All Alloy Cup progress - by Chris KC - 13-07-2019, 07:40 PM
RE: All Alloy Cup progress - by Austin Carr - 13-07-2019, 08:22 PM
RE: All Alloy Cup progress - by AllAlloyCup - 13-07-2019, 10:40 PM
RE: All Alloy Cup progress - by AllAlloyCup - 18-07-2019, 04:57 PM
RE: All Alloy Cup progress - by spannerman - 18-07-2019, 06:21 PM
RE: All Alloy Cup progress - by squeak - 19-07-2019, 01:41 AM
RE: All Alloy Cup progress - by AllAlloyCup - 19-07-2019, 07:32 AM
RE: All Alloy Cup progress - by Nick Lettington - 19-07-2019, 09:32 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 19-07-2019, 09:44 AM
RE: All Alloy Cup progress - by AllAlloyCup - 19-07-2019, 05:59 PM
RE: All Alloy Cup progress - by Malcolm Parker - 19-07-2019, 08:50 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-07-2019, 09:39 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 24-07-2019, 09:44 PM
RE: All Alloy Cup progress - by David Stepney - 24-07-2019, 09:53 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-07-2019, 09:55 PM
RE: All Alloy Cup progress - by Howard Wright - 24-07-2019, 09:59 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-07-2019, 10:21 PM
RE: All Alloy Cup progress - by Tony Betts - 24-07-2019, 10:32 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-07-2019, 11:10 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 24-07-2019, 11:26 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-07-2019, 11:34 PM
RE: All Alloy Cup progress - by AustinWood - 25-07-2019, 09:22 AM
RE: All Alloy Cup progress - by AllAlloyCup - 25-07-2019, 09:54 AM
RE: All Alloy Cup progress - by Nick Lettington - 25-07-2019, 10:45 AM
RE: All Alloy Cup progress - by Hedd_Jones - 25-07-2019, 11:09 AM
RE: All Alloy Cup progress - by AllAlloyCup - 25-07-2019, 01:18 PM
RE: All Alloy Cup progress - by AllAlloyCup - 26-07-2019, 10:33 PM
RE: All Alloy Cup progress - by AllAlloyCup - 30-07-2019, 08:20 AM
RE: All Alloy Cup progress - by Mike Costigan - 30-07-2019, 09:05 AM
RE: All Alloy Cup progress - by AllAlloyCup - 30-07-2019, 09:30 AM
RE: All Alloy Cup progress - by AllAlloyCup - 31-07-2019, 10:08 PM
RE: All Alloy Cup progress - by AllAlloyCup - 01-08-2019, 10:08 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 01-08-2019, 06:19 PM
RE: All Alloy Cup progress - by AllAlloyCup - 01-08-2019, 08:12 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 01-08-2019, 09:42 PM
RE: All Alloy Cup progress - by AllAlloyCup - 03-08-2019, 11:00 AM
RE: All Alloy Cup progress - by AllAlloyCup - 09-08-2019, 08:31 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 10-08-2019, 09:51 AM
RE: All Alloy Cup progress - by Howard Wright - 10-08-2019, 10:21 AM
RE: All Alloy Cup progress - by AllAlloyCup - 10-08-2019, 02:32 PM
RE: All Alloy Cup progress - by AllAlloyCup - 18-08-2019, 02:40 PM
RE: All Alloy Cup progress - by AllAlloyCup - 21-08-2019, 05:44 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 21-08-2019, 05:55 PM
RE: All Alloy Cup progress - by Ian Williams - 21-08-2019, 08:53 PM
RE: All Alloy Cup progress - by AllAlloyCup - 21-08-2019, 09:08 PM
RE: All Alloy Cup progress - by AllAlloyCup - 20-05-2020, 09:58 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 20-05-2020, 10:01 AM
RE: All Alloy Cup progress - by AllAlloyCup - 20-05-2020, 10:21 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 20-05-2020, 10:32 AM
RE: All Alloy Cup progress - by Bob Olive - 12-10-2020, 08:34 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 12-10-2020, 08:37 AM
RE: All Alloy Cup progress - by AllAlloyCup - 12-10-2020, 10:06 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 12-10-2020, 10:19 AM
RE: All Alloy Cup progress - by Mike Costigan - 12-10-2020, 11:24 AM
RE: All Alloy Cup progress - by AllAlloyCup - 12-10-2020, 12:24 PM
RE: All Alloy Cup progress - by JonE - 12-10-2020, 01:42 PM
RE: All Alloy Cup progress - by Mike Costigan - 12-10-2020, 02:57 PM
RE: All Alloy Cup progress - by AllAlloyCup - 24-10-2020, 09:30 PM
RE: All Alloy Cup progress - by Mike Costigan - 25-10-2020, 09:56 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 25-10-2020, 10:39 AM
RE: All Alloy Cup progress - by Tony Griffiths - 26-10-2020, 06:47 PM
RE: All Alloy Cup progress - by AllAlloyCup - 27-10-2020, 06:34 PM
RE: All Alloy Cup progress - by squeak - 28-10-2020, 12:12 AM
RE: All Alloy Cup progress - by AllAlloyCup - 29-10-2020, 10:24 PM
RE: All Alloy Cup progress - by Howard Wright - 29-10-2020, 10:32 PM
RE: All Alloy Cup progress - by squeak - 30-10-2020, 12:46 AM
RE: All Alloy Cup progress - by Mark Dymond - 30-10-2020, 12:51 AM
RE: All Alloy Cup progress - by AllAlloyCup - 17-01-2021, 06:09 PM
RE: All Alloy Cup progress - by Peter Johnson - 17-01-2021, 07:49 PM
RE: All Alloy Cup progress - by AllAlloyCup - 17-01-2021, 09:15 PM
RE: All Alloy Cup progress - by AllAlloyCup - 19-01-2021, 06:47 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 19-01-2021, 07:01 PM
RE: All Alloy Cup progress - by AllAlloyCup - 19-01-2021, 08:34 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 19-01-2021, 09:52 PM
RE: All Alloy Cup progress - by Peter Johnson - 20-01-2021, 07:47 PM
RE: All Alloy Cup progress - by AllAlloyCup - 20-01-2021, 08:34 PM
RE: All Alloy Cup progress - by Renaud - 21-01-2021, 10:20 AM
RE: All Alloy Cup progress - by Malcolm Parker - 21-01-2021, 11:25 AM
RE: All Alloy Cup progress - by AllAlloyCup - 26-01-2021, 04:57 PM
RE: All Alloy Cup progress - by Steve Jones - 26-01-2021, 05:09 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 26-01-2021, 05:13 PM
RE: All Alloy Cup progress - by AllAlloyCup - 26-01-2021, 05:30 PM
RE: All Alloy Cup progress - by Mike Costigan - 26-01-2021, 05:52 PM
RE: All Alloy Cup progress - by AllAlloyCup - 26-01-2021, 07:01 PM
RE: All Alloy Cup progress - by Renaud - 26-01-2021, 07:11 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 26-01-2021, 07:54 PM
RE: All Alloy Cup progress - by Howard Wright - 26-01-2021, 08:24 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 26-01-2021, 08:24 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 26-01-2021, 08:47 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 26-01-2021, 09:12 PM
RE: All Alloy Cup progress - by AllAlloyCup - 27-01-2021, 11:08 AM
RE: All Alloy Cup progress - by Malcolm Parker - 27-01-2021, 01:54 PM
RE: All Alloy Cup progress - by Malcolm Parker - 27-01-2021, 04:51 PM
RE: All Alloy Cup progress - by AllAlloyCup - 27-01-2021, 08:44 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 28-01-2021, 06:59 PM
RE: All Alloy Cup progress - by AllAlloyCup - 27-04-2022, 09:04 PM
RE: All Alloy Cup progress - by AllAlloyCup - 02-02-2023, 10:27 PM
RE: All Alloy Cup progress - by Hugh Barnes - 02-02-2023, 10:49 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 02-02-2023, 11:13 PM
RE: All Alloy Cup progress - by Howard Wright - 03-02-2023, 08:32 AM
RE: All Alloy Cup progress - by Ruairidh Dunford - 03-02-2023, 08:40 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 03-02-2023, 08:58 AM
RE: All Alloy Cup progress - by AllAlloyCup - 03-02-2023, 08:55 PM
RE: All Alloy Cup progress - by Colin Cooke - 04-02-2023, 08:16 AM
RE: All Alloy Cup progress - by Malcolm Parker - 04-02-2023, 10:22 AM
RE: All Alloy Cup progress - by AllAlloyCup - 07-02-2023, 05:36 PM
RE: All Alloy Cup progress - by Ruairidh Dunford - 07-02-2023, 06:15 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 07-02-2023, 07:48 PM
RE: All Alloy Cup progress - by Howard Wright - 07-02-2023, 07:59 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 07-02-2023, 08:47 PM
RE: All Alloy Cup progress - by Oxford Jack - 07-02-2023, 10:34 PM
RE: All Alloy Cup progress - by Jeff Taylor - 08-02-2023, 02:51 AM
RE: All Alloy Cup progress - by Tony Press - 08-02-2023, 04:43 AM
RE: All Alloy Cup progress - by Duncan Grimmond - 08-02-2023, 09:10 AM
RE: All Alloy Cup progress - by Oxford Jack - 09-02-2023, 07:25 PM
RE: All Alloy Cup progress - by AllAlloyCup - 09-02-2023, 08:53 PM
RE: All Alloy Cup progress - by AustinWood - 10-02-2023, 12:46 PM
RE: All Alloy Cup progress - by AllAlloyCup - 10-02-2023, 03:19 PM
RE: All Alloy Cup progress - by AllAlloyCup - 20-02-2023, 09:44 PM
RE: All Alloy Cup progress - by AllAlloyCup - 21-02-2023, 06:09 PM
RE: All Alloy Cup progress - by AllAlloyCup - 01-03-2023, 10:41 AM
RE: All Alloy Cup progress - by David Cochrane - 01-03-2023, 09:26 PM
RE: All Alloy Cup progress - by AllAlloyCup - 03-03-2023, 03:37 PM
RE: All Alloy Cup progress - by Duncan Grimmond - 03-03-2023, 08:19 PM
RE: All Alloy Cup progress - by Dave Mann - 04-03-2023, 11:02 AM
RE: All Alloy Cup progress - by David Cochrane - 05-03-2023, 02:51 PM
RE: All Alloy Cup progress - by Mike Costigan - 05-03-2023, 05:00 PM
RE: All Alloy Cup progress - by Ivor Hawkins - 05-03-2023, 05:13 PM
RE: All Alloy Cup progress - by AllAlloyCup - 07-03-2023, 10:39 AM
RE: All Alloy Cup progress - by AllAlloyCup - 08-03-2023, 10:01 PM
RE: GE Cup progress - by AllAlloyCup - 08-08-2017, 04:37 PM
RE: GE Cup progress - by Timothy P - 08-08-2017, 05:16 PM
RE: GE Cup progress - by AllAlloyCup - 09-08-2017, 05:31 PM
RE: GE Cup progress - by AllAlloyCup - 09-08-2017, 06:43 PM
RE: GE Cup progress - by Timothy P - 09-08-2017, 06:47 PM
RE: GE Cup progress - by Duncan Grimmond - 09-08-2017, 07:00 PM
RE: GE Cup progress - by AllAlloyCup - 09-08-2017, 10:35 PM
RE: GE Cup progress - by Timothy P - 10-08-2017, 12:47 AM
RE: GE Cup progress - by AllAlloyCup - 10-08-2017, 08:51 AM
RE: GE Cup progress - by Ruairidh Dunford - 10-08-2017, 09:35 AM
RE: GE Cup progress - by Ian Williams - 10-08-2017, 10:00 AM
RE: GE Cup progress - by AllAlloyCup - 10-08-2017, 11:18 AM
RE: GE Cup progress - by Ruairidh Dunford - 10-08-2017, 11:33 AM
RE: GE Cup progress - by Ian Williams - 10-08-2017, 11:57 AM
RE: GE Cup progress - by Timothy P - 10-08-2017, 12:35 PM
RE: GE Cup progress - by Ruairidh Dunford - 10-08-2017, 12:43 PM
RE: GE Cup progress - by AllAlloyCup - 10-08-2017, 01:07 PM
GE Cup Special progress - by AllAlloyCup - 03-03-2018, 12:10 AM
RE: GE Cup Special progress - by Nick Lettington - 03-03-2018, 12:17 AM
RE: GE Cup Special progress - by Timothy P - 04-03-2018, 03:12 PM
RE: GE Cup Special progress - by Bryan Downes - 04-03-2018, 04:52 PM
RE: GE Cup Special progress - by AllAlloyCup - 04-03-2018, 08:14 PM
RE: GE Cup Special progress - by Ruairidh Dunford - 04-03-2018, 08:23 PM
RE: GE Cup Special progress - by AllAlloyCup - 03-04-2018, 05:04 PM
RE: GE Cup Special progress - by Ruairidh Dunford - 03-04-2018, 05:31 PM
AllAlloyCup progress - by AllAlloyCup - 01-10-2018, 06:39 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-10-2018, 12:40 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 08-10-2018, 12:43 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-10-2018, 01:29 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 08-10-2018, 01:46 PM
RE: AllAlloyCup progress - by Timothy P - 09-10-2018, 10:15 AM
RE: AllAlloyCup progress - by AllAlloyCup - 09-10-2018, 04:58 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-10-2018, 05:29 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 09-10-2018, 06:02 PM
RE: AllAlloyCup progress - by AllAlloyCup - 09-10-2018, 06:26 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-10-2018, 06:53 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-10-2018, 09:46 AM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-10-2018, 09:55 AM
RE: AllAlloyCup progress - by Peter Johnson - 10-10-2018, 11:11 AM
RE: AllAlloyCup progress - by AllAlloyCup - 10-10-2018, 11:36 AM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-10-2018, 11:49 AM
RE: AllAlloyCup progress - by Peter Johnson - 10-10-2018, 01:42 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-10-2018, 01:50 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-10-2018, 01:52 PM
RE: AllAlloyCup progress - by Peter Johnson - 10-10-2018, 09:28 PM
RE: AllAlloyCup progress - by AllAlloyCup - 11-10-2018, 05:13 PM
RE: AllAlloyCup progress - by AllAlloyCup - 02-11-2018, 02:42 PM
RE: AllAlloyCup progress - by AllAlloyCup - 07-11-2018, 09:53 PM
RE: AllAlloyCup progress - by Timothy P - 08-11-2018, 11:11 AM
RE: AllAlloyCup progress - by JonE - 08-11-2018, 11:21 AM
RE: AllAlloyCup progress - by AllAlloyCup - 08-11-2018, 11:31 AM
RE: AllAlloyCup progress - by AllAlloyCup - 08-11-2018, 01:37 PM
RE: AllAlloyCup progress - by AllAlloyCup - 14-11-2018, 12:05 AM
RE: AllAlloyCup progress - by JonE - 14-11-2018, 08:38 AM
RE: AllAlloyCup progress - by Mike Costigan - 14-11-2018, 09:32 AM
RE: AllAlloyCup progress - by jansens - 14-11-2018, 09:50 AM
RE: AllAlloyCup progress - by AllAlloyCup - 14-11-2018, 10:23 AM
RE: AllAlloyCup progress - by jansens - 14-11-2018, 11:41 AM
RE: AllAlloyCup progress - by AllAlloyCup - 14-11-2018, 11:12 PM
RE: AllAlloyCup progress - by Tony Press - 14-11-2018, 11:39 PM
RE: AllAlloyCup progress - by David.H - 14-11-2018, 11:45 PM
RE: AllAlloyCup progress - by Chris KC - 16-11-2018, 05:44 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 15-11-2018, 09:13 AM
RE: AllAlloyCup progress - by AllAlloyCup - 15-11-2018, 11:02 AM
RE: AllAlloyCup progress - by Duncan Grimmond - 15-11-2018, 09:53 PM
RE: AllAlloyCup progress - by JonE - 16-11-2018, 10:58 AM
RE: AllAlloyCup progress - by AllAlloyCup - 16-11-2018, 12:36 PM
RE: AllAlloyCup progress - by Colin Reed - 18-11-2018, 08:17 PM
RE: AllAlloyCup progress - by Jeff Taylor - 18-11-2018, 09:57 PM
RE: AllAlloyCup progress - by AllAlloyCup - 18-11-2018, 10:34 PM
RE: AllAlloyCup progress - by Colin Reed - 19-11-2018, 02:41 AM
RE: AllAlloyCup progress - by AllAlloyCup - 25-11-2018, 08:36 PM
RE: AllAlloyCup progress - by Tony Press - 25-11-2018, 11:18 PM
RE: AllAlloyCup progress - by AllAlloyCup - 26-11-2018, 05:48 PM
RE: AllAlloyCup progress - by David.H - 26-11-2018, 06:18 PM
RE: AllAlloyCup progress - by AllAlloyCup - 26-11-2018, 07:34 PM
RE: AllAlloyCup progress - by John Mason - 26-11-2018, 09:28 PM
RE: AllAlloyCup progress - by AllAlloyCup - 26-11-2018, 10:54 PM
RE: AllAlloyCup progress - by Dave Wortley - 27-11-2018, 10:12 AM
RE: AllAlloyCup progress - by John Mason - 27-11-2018, 10:15 AM
RE: AllAlloyCup progress - by JonE - 27-11-2018, 11:15 AM
RE: AllAlloyCup progress - by AllAlloyCup - 27-11-2018, 11:27 AM
RE: AllAlloyCup progress - by David Cochrane - 27-11-2018, 10:38 PM
RE: AllAlloyCup progress - by Howard Wright - 27-11-2018, 10:59 PM
RE: AllAlloyCup progress - by AllAlloyCup - 28-11-2018, 12:09 AM
RE: AllAlloyCup progress - by AllAlloyCup - 30-11-2018, 12:50 PM
RE: AllAlloyCup progress - by Austin Carr - 30-11-2018, 04:10 PM
RE: AllAlloyCup progress - by Colin Reed - 30-11-2018, 08:29 PM
RE: AllAlloyCup progress - by Michael D - 01-12-2018, 11:13 AM
RE: AllAlloyCup progress - by AllAlloyCup - 01-12-2018, 01:13 PM
RE: AllAlloyCup progress - by Mike Costigan - 01-12-2018, 01:44 PM
RE: AllAlloyCup progress - by Erich - 01-12-2018, 02:30 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-12-2018, 04:49 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 01-12-2018, 07:06 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-12-2018, 07:20 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 01-12-2018, 07:30 PM
RE: AllAlloyCup progress - by AllAlloyCup - 02-12-2018, 12:25 PM
RE: AllAlloyCup progress - by AllAlloyCup - 02-12-2018, 08:33 PM
RE: AllAlloyCup progress - by Haggis - 04-12-2018, 10:46 AM
RE: AllAlloyCup progress - by Hedd_Jones - 04-12-2018, 11:42 AM
RE: AllAlloyCup progress - by AllAlloyCup - 04-12-2018, 12:39 PM
RE: AllAlloyCup progress - by Malcolm Parker - 04-12-2018, 12:46 PM
RE: AllAlloyCup progress - by JonE - 04-12-2018, 01:19 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 04-12-2018, 01:46 PM
RE: AllAlloyCup progress - by AllAlloyCup - 05-12-2018, 12:46 PM
RE: AllAlloyCup progress - by Steve Jones - 05-12-2018, 01:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 05-12-2018, 01:37 PM
RE: AllAlloyCup progress - by Erich - 05-12-2018, 06:17 PM
RE: AllAlloyCup progress - by AllAlloyCup - 18-12-2018, 08:59 PM
RE: AllAlloyCup progress - by Zetomagneto - 18-12-2018, 11:29 PM
RE: AllAlloyCup progress - by AllAlloyCup - 19-12-2018, 12:38 AM
RE: AllAlloyCup progress - by Tony Press - 19-12-2018, 01:49 AM
RE: AllAlloyCup progress - by Mike Costigan - 19-12-2018, 10:04 AM
RE: AllAlloyCup progress - by AllAlloyCup - 19-12-2018, 10:35 AM
RE: AllAlloyCup progress - by Timothy P - 19-12-2018, 11:09 AM
RE: AllAlloyCup progress - by Mike Costigan - 19-12-2018, 11:21 AM
RE: AllAlloyCup progress - by AllAlloyCup - 19-12-2018, 11:35 AM
RE: AllAlloyCup progress - by Tony Press - 19-12-2018, 09:45 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 19-12-2018, 10:16 PM
RE: AllAlloyCup progress - by wild_willy - 23-12-2018, 02:02 AM
RE: AllAlloyCup progress - by Tony Press - 23-12-2018, 06:55 AM
RE: AllAlloyCup progress - by AllAlloyCup - 23-12-2018, 09:46 AM
RE: AllAlloyCup progress - by Tony Press - 23-12-2018, 10:53 PM
RE: AllAlloyCup progress - by andrew34ruby - 24-12-2018, 11:35 AM
RE: AllAlloyCup progress - by AustinWood - 23-12-2018, 11:38 AM
RE: AllAlloyCup progress - by Steve Jones - 23-12-2018, 12:41 PM
RE: AllAlloyCup progress - by jansens - 23-12-2018, 08:24 PM
RE: AllAlloyCup progress - by AllAlloyCup - 23-12-2018, 09:26 PM
RE: AllAlloyCup progress - by jansens - 23-12-2018, 11:25 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-01-2019, 04:51 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 10-01-2019, 06:00 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-01-2019, 07:11 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 10-01-2019, 09:45 PM
RE: AllAlloyCup progress - by AllAlloyCup - 17-01-2019, 05:33 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 17-01-2019, 06:08 PM
RE: AllAlloyCup progress - by AllAlloyCup - 17-01-2019, 06:44 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 17-01-2019, 06:52 PM
RE: AllAlloyCup progress - by AllAlloyCup - 17-01-2019, 08:02 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 17-01-2019, 08:11 PM
RE: AllAlloyCup progress - by David Cochrane - 18-01-2019, 10:25 PM
RE: AllAlloyCup progress - by AllAlloyCup - 18-01-2019, 11:50 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 19-01-2019, 07:28 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-01-2019, 06:30 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 22-01-2019, 06:56 PM
RE: AllAlloyCup progress - by Chris KC - 22-01-2019, 07:53 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-01-2019, 09:07 PM
RE: AllAlloyCup progress - by Steve Jones - 22-01-2019, 09:16 PM
RE: AllAlloyCup progress - by Mike Costigan - 22-01-2019, 09:53 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-01-2019, 10:45 PM
RE: AllAlloyCup progress - by Timothy P - 22-01-2019, 10:59 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-01-2019, 11:16 PM
RE: AllAlloyCup progress - by AllAlloyCup - 23-01-2019, 11:46 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-01-2019, 05:14 PM
RE: AllAlloyCup progress - by Hedd_Jones - 27-01-2019, 09:09 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-01-2019, 09:37 PM
RE: AllAlloyCup progress - by Chris KC - 27-01-2019, 10:32 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-01-2019, 11:15 PM
RE: AllAlloyCup progress - by Chris KC - 28-01-2019, 06:45 PM
RE: AllAlloyCup progress - by AllAlloyCup - 28-01-2019, 06:03 PM
RE: AllAlloyCup progress - by Reckless Rat - 28-01-2019, 06:51 PM
RE: AllAlloyCup progress - by AllAlloyCup - 29-01-2019, 04:42 PM
RE: AllAlloyCup progress - by AllAlloyCup - 30-01-2019, 09:38 PM
RE: AllAlloyCup progress - by Reckless Rat - 30-01-2019, 09:45 PM
RE: AllAlloyCup progress - by JonE - 30-01-2019, 09:54 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 30-01-2019, 10:54 PM
RE: AllAlloyCup progress - by AllAlloyCup - 30-01-2019, 11:23 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 30-01-2019, 11:28 PM
RE: AllAlloyCup progress - by AllAlloyCup - 31-01-2019, 08:40 AM
RE: AllAlloyCup progress - by AllAlloyCup - 31-01-2019, 06:51 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 31-01-2019, 06:57 PM
RE: AllAlloyCup progress - by JonE - 01-02-2019, 09:35 AM
RE: AllAlloyCup progress - by AllAlloyCup - 01-02-2019, 09:53 AM
RE: AllAlloyCup progress - by Malcolm Parker - 01-02-2019, 02:46 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-02-2019, 04:06 PM
RE: AllAlloyCup progress - by Steve Jones - 01-02-2019, 04:55 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-02-2019, 05:02 PM
RE: AllAlloyCup progress - by Steve Jones - 01-02-2019, 05:24 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-02-2019, 05:51 PM
RE: AllAlloyCup progress - by Malcolm Parker - 02-02-2019, 09:34 AM
RE: AllAlloyCup progress - by AllAlloyCup - 03-02-2019, 06:28 PM
RE: AllAlloyCup progress - by AllAlloyCup - 05-02-2019, 12:13 PM
RE: AllAlloyCup progress - by Hedd_Jones - 05-02-2019, 12:59 PM
RE: AllAlloyCup progress - by AllAlloyCup - 05-02-2019, 01:20 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-02-2019, 06:04 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-02-2019, 06:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-02-2019, 08:20 PM
RE: AllAlloyCup progress - by jansens - 10-02-2019, 08:51 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-02-2019, 09:12 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-02-2019, 09:23 PM
RE: AllAlloyCup progress - by jansens - 10-02-2019, 10:18 PM
RE: AllAlloyCup progress - by AllAlloyCup - 11-02-2019, 08:38 PM
RE: AllAlloyCup progress - by AllAlloyCup - 14-02-2019, 06:28 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 14-02-2019, 06:30 PM
RE: AllAlloyCup progress - by AllAlloyCup - 14-02-2019, 06:45 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 14-02-2019, 07:17 PM
RE: AllAlloyCup progress - by AllAlloyCup - 14-02-2019, 07:29 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 14-02-2019, 07:40 PM
RE: AllAlloyCup progress - by AllAlloyCup - 21-02-2019, 07:09 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 21-02-2019, 07:22 PM
RE: AllAlloyCup progress - by Greig Smith - 21-02-2019, 07:25 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-02-2019, 01:09 PM
RE: AllAlloyCup progress - by Mike Costigan - 22-02-2019, 05:19 PM
RE: AllAlloyCup progress - by AllAlloyCup - 22-02-2019, 05:49 PM
RE: AllAlloyCup progress - by AllAlloyCup - 25-02-2019, 04:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 26-02-2019, 03:01 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 27-02-2019, 05:54 PM
RE: AllAlloyCup progress - by jansens - 27-02-2019, 06:30 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-02-2019, 08:27 PM
RE: AllAlloyCup progress - by Colin Reed - 27-02-2019, 09:25 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-02-2019, 10:16 PM
RE: AllAlloyCup progress - by jansens - 27-02-2019, 10:22 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 27-02-2019, 10:34 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-03-2019, 05:21 PM
RE: AllAlloyCup progress - by Mike Costigan - 01-03-2019, 06:41 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-03-2019, 07:16 PM
RE: AllAlloyCup progress - by Jamie - 01-03-2019, 08:13 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 01-03-2019, 08:15 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-03-2019, 09:15 PM
RE: AllAlloyCup progress - by Hedd_Jones - 01-03-2019, 09:51 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-03-2019, 10:26 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 01-03-2019, 10:35 PM
RE: AllAlloyCup progress - by Hedd_Jones - 01-03-2019, 11:27 PM
RE: AllAlloyCup progress - by AllAlloyCup - 01-03-2019, 11:36 PM
RE: AllAlloyCup progress - by Hedd_Jones - 01-03-2019, 11:50 PM
RE: AllAlloyCup progress - by AllAlloyCup - 03-03-2019, 12:17 AM
RE: AllAlloyCup progress - by AllAlloyCup - 03-03-2019, 10:21 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-03-2019, 11:40 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 09-03-2019, 01:00 AM
RE: AllAlloyCup progress - by AllAlloyCup - 09-03-2019, 10:03 AM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 10:34 AM
RE: AllAlloyCup progress - by AllAlloyCup - 09-03-2019, 11:37 AM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 11:52 AM
RE: AllAlloyCup progress - by Peter Johnson - 09-03-2019, 02:30 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 02:47 PM
RE: AllAlloyCup progress - by AllAlloyCup - 09-03-2019, 02:51 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 02:59 PM
RE: AllAlloyCup progress - by AustinWood - 09-03-2019, 03:16 PM
RE: AllAlloyCup progress - by AllAlloyCup - 09-03-2019, 04:53 PM
RE: AllAlloyCup progress - by AustinWood - 09-03-2019, 06:43 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 11:17 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 09-03-2019, 11:41 PM
RE: AllAlloyCup progress - by Tom Coates - 10-03-2019, 01:02 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 10-03-2019, 01:33 PM
RE: AllAlloyCup progress - by bob46320 - 10-03-2019, 03:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-03-2019, 06:12 PM
RE: AllAlloyCup progress - by JonE - 10-03-2019, 06:39 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-03-2019, 06:50 PM
RE: AllAlloyCup progress - by Tom Coates - 10-03-2019, 09:41 PM
RE: AllAlloyCup progress - by AllAlloyCup - 10-03-2019, 10:04 PM
RE: AllAlloyCup progress - by AllAlloyCup - 12-03-2019, 06:16 PM
RE: AllAlloyCup progress - by AllAlloyCup - 13-03-2019, 06:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 14-03-2019, 08:08 PM
RE: AllAlloyCup progress - by AllAlloyCup - 18-03-2019, 06:13 PM
RE: AllAlloyCup progress - by AllAlloyCup - 20-03-2019, 06:10 PM
RE: AllAlloyCup progress - by AllAlloyCup - 23-03-2019, 09:06 PM
RE: AllAlloyCup progress - by Erich - 24-03-2019, 11:20 PM
RE: AllAlloyCup progress - by Malcolm Parker - 25-03-2019, 09:47 AM
RE: AllAlloyCup progress - by AllAlloyCup - 25-03-2019, 10:10 AM
RE: AllAlloyCup progress - by Erich - 25-03-2019, 05:26 PM
RE: AllAlloyCup progress - by AllAlloyCup - 27-03-2019, 10:25 PM
RE: AllAlloyCup progress - by Duncan Grimmond - 28-03-2019, 09:03 AM
RE: AllAlloyCup progress - by AllAlloyCup - 28-03-2019, 09:31 AM
RE: AllAlloyCup progress - by AllAlloyCup - 28-03-2019, 02:24 PM
RE: AllAlloyCup progress - by Hedd_Jones - 28-03-2019, 04:24 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 28-03-2019, 04:44 PM
RE: AllAlloyCup progress - by AllAlloyCup - 28-03-2019, 05:13 PM
RE: AllAlloyCup progress - by Hedd_Jones - 28-03-2019, 06:52 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 28-03-2019, 07:08 PM
RE: AllAlloyCup progress - by Hedd_Jones - 28-03-2019, 07:36 PM
RE: AllAlloyCup progress - by AllAlloyCup - 28-03-2019, 07:39 PM
RE: AllAlloyCup progress - by Hedd_Jones - 28-03-2019, 08:24 PM
RE: AllAlloyCup progress - by AllAlloyCup - 29-03-2019, 06:59 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 30-03-2019, 09:04 AM
RE: AllAlloyCup progress - by AllAlloyCup - 30-03-2019, 09:27 AM
RE: AllAlloyCup progress - by Ruairidh Dunford - 30-03-2019, 09:39 AM
RE: AllAlloyCup progress - by AllAlloyCup - 30-03-2019, 04:17 PM
RE: AllAlloyCup progress - by Peter Johnson - 30-03-2019, 07:03 PM
RE: AllAlloyCup progress - by MartinH - 30-03-2019, 07:11 PM
RE: AllAlloyCup progress - by AllAlloyCup - 31-03-2019, 02:45 PM
RE: AllAlloyCup progress - by AllAlloyCup - 04-04-2019, 10:10 AM
RE: AllAlloyCup progress - by David Stepney - 04-04-2019, 12:18 PM
RE: AllAlloyCup progress - by JonE - 04-04-2019, 01:12 PM
RE: AllAlloyCup progress - by AllAlloyCup - 04-04-2019, 01:51 PM
RE: AllAlloyCup progress - by Austin Carr - 04-04-2019, 02:59 PM
RE: AllAlloyCup progress - by AllAlloyCup - 04-04-2019, 03:17 PM
RE: AllAlloyCup progress - by AllAlloyCup - 06-04-2019, 12:15 PM
RE: AllAlloyCup progress - by AllAlloyCup - 07-04-2019, 02:41 PM
RE: AllAlloyCup progress - by David Stepney - 07-04-2019, 03:22 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 07-04-2019, 03:30 PM
RE: AllAlloyCup progress - by Hedd_Jones - 07-04-2019, 03:38 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 07-04-2019, 03:47 PM
RE: AllAlloyCup progress - by AllAlloyCup - 07-04-2019, 04:10 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 07-04-2019, 04:20 PM
RE: AllAlloyCup progress - by Hedd_Jones - 07-04-2019, 05:05 PM
RE: AllAlloyCup progress - by Ruairidh Dunford - 07-04-2019, 05:58 PM
RE: AllAlloyCup progress - by AllAlloyCup - 07-04-2019, 07:00 PM
RE: AllAlloyCup progress - by jansens - 07-04-2019, 11:41 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-04-2019, 04:27 PM
RE: AllAlloyCup progress - by jansens - 08-04-2019, 06:22 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-04-2019, 07:31 PM
RE: AllAlloyCup progress - by Mike Costigan - 08-04-2019, 09:44 PM
RE: AllAlloyCup progress - by AllAlloyCup - 08-04-2019, 10:40 PM
