SU 1' OM type damper cap type
I run with an OM carb, no damper, I believe that the correct circular brass cap has a vent hole, a coin slot, a knurled edge, and is engraved "use bicycle oil". Burlen part No. AUC 2144SBO. (don't forget a fibre washer to suit AUC 4900)
     I lost a couple before, as Steve Jones suggests, I nipped them up with water pump pliers every installation, since then no problems. Shy
SU 1' OM type damper cap type - by Robin Gooders - 29-04-2019, 08:51 AM
RE: SU 1' OM type damper cap type - by Alan - 29-04-2019, 08:54 AM
RE: SU 1' OM type damper cap type - by Bob Culver - 29-04-2019, 04:00 PM
RE: SU 1' OM type damper cap type - by stuartu - 29-04-2019, 06:09 PM
RE: SU 1' OM type damper cap type - by Ian McGowan - 29-04-2019, 08:28 PM
RE: SU 1' OM type damper cap type - by jansens - 29-04-2019, 09:12 PM
RE: SU 1' OM type damper cap type - by Charles P - 29-04-2019, 11:08 PM
RE: SU 1' OM type damper cap type - by Tony Press - 29-04-2019, 11:29 PM
