front spring position adjustment?
As I recall, Jon, there is a bolt right through all the leaves so you should see a nut under the bottom leaf. Of course, anything could be going on under the chassis nosepiece.
If the bolt has fractured then the lower leaves could move sideways. I don't suppose the bolt would drop out but if it were very easy to turn its nut and the bolt moved with it I would be dismantling further.
Regards,
Stuart
front spring position adjustment? - by JonE - 27-04-2019, 12:39 PM
RE: front spring position adjustment? - by JonE - 27-04-2019, 01:22 PM
RE: front spring position adjustment? - by stuartu - 27-04-2019, 03:34 PM
RE: front spring position adjustment? - by JonE - 27-04-2019, 04:06 PM
RE: front spring position adjustment? - by JonE - 28-04-2019, 08:44 AM
RE: front spring position adjustment? - by JonE - 29-04-2019, 01:30 PM
RE: front spring position adjustment? - by JonE - 29-04-2019, 01:50 PM
