26-04-2019, 06:29 PM
Hi Dennis
What sort of flasher unit are you using ? If it's electronic, its possible that it doesn't take kindly to the amount of electrical noise on the Austin's 6 volt supply. This comes mostly from the ignition system when the engine is running.
A filtering cure may be possible, but we need more detail of your setup first. Alternatively an older fashioned thermal type flasher may be a better bet.
Cheers, John.
Cheers, John.
