25-04-2019, 03:43 PM
(This post was last modified: 25-04-2019, 04:24 PM by Peter Sweeney.)
Don't know if the attachments will be there but I have sent 2 photos of the brake cross shaft where it meets the front cable. I have full Girling brakes on both my Big 7 and Ruby special I recently bought a new yoke etc illustrated with the spare cross shaft (Ruby). My Query is when did the threaded screw in pin come into use. Was it only on the full Girling cars as it is on both of my cars and this spare shaft. None of them are threaded for the yoke to be screwed through. This makes it easier to set the tension on the front cable. As you push the threaded part of the yoke through the pin tighten it with the nut and lock it with a lock nut. Any thoughts
[attachment=6220][attachment=6220]
