24-04-2019, 09:53 AM
The Car to do list
Fix petrol tap, and fuel filter
Grind and paint exhaust manifold, fit. DONE
Fix valve chest cover with O-ring cord. DONE
Fix brake light switch and wiring DONE
Wire umbilical to control panel
Attach steering drag link
Install windscreen glass(wiper motor holes?)
Paint: throttle shaft, toe board etc refit DONE
Sort out pedals and gearbox top. DONE
Test petrol tank and refit ( slosh if need be?)
Make and fit oil pipe
Make and fit handbrake gaiter.
Adjust brakes refit under-sills. DONE
Fit engine in chassis DONE
Fit carburettor and linkages. DONE
Make and fit exhaust down pipe
Refit flitches, cow horns and wing supports
Rewire remaining cabling
Fit new battery cable and battery. DONE
Finalise floorboards,TransTunnel and seating. SOME
Check starter and dynamo and fit
Time engine with old distributor
Refit radiator etc and bonnet
Nickel plate door catches etc,
Refit doors
Fix headlamps
Attach all wings, side lamps and flasher
Fill all fluids and attend to all greasing points
Finish instruments
Make carpets
Order hood material Make tonneau
Commission hood and side-screens
Steady progress
Regards
Bill G
Refit doors
Fix headlamps
Finish instruments
Make carpets
Steady progress
Regards
Bill G
