Crank case to block studs
I have been using Seven Workshop big end bolts for 2 engine rebuilds recently. They have been used as big end bolts for only a low mileage after water ingress into the sump. Also used Seven Workshop silicone block to c/case gasket which is leak free.
RE: Crank case to block studs - by Chris KC - 18-04-2019, 07:51 AM
RE: Crank case to block studs - by Ian Williams - 18-04-2019, 08:21 AM
RE: Crank case to block studs - by Alan - 18-04-2019, 08:53 AM
RE: Crank case to block studs - by Speedex750 - 18-04-2019, 09:01 AM
RE: Crank case to block studs - by Ian Williams - 18-04-2019, 08:23 PM
RE: Crank case to block studs - by Alan - 18-04-2019, 10:03 PM
RE: Crank case to block studs - by Ian Williams - 19-04-2019, 06:07 AM
RE: Crank case to block studs - by AustinWood - 19-04-2019, 10:35 AM
RE: Crank case to block studs - by Greig Smith - 20-04-2019, 09:59 AM
RE: Crank case to block studs - by AustinWood - 20-04-2019, 10:06 AM
RE: Crank case to block studs - by Chris KC - 20-04-2019, 11:46 AM
RE: Crank case to block studs - by AustinWood - 20-04-2019, 12:19 PM
RE: Crank case to block studs - by Dave Wortley - 20-04-2019, 04:35 PM
