12 Volt Field Coils
I run an electronic regulator designed for the purpose of running a 6V 3 brush at 12v 2 brush it was originally designed for motorcycles and it works flawlessly.  However the engine must to doing at least 1500rpm to get a charge and when idling  it goes negative 8 Amps.  I have been thinking of buying some 12V field coils available in the UK for about 60 GBP at https://www.eics-products.co.uk/shop/cla...eld-coils/ I think these would work to reduce the current needed to get a charge.
The regulator I use came from: http://aoservices.co.uk/car.htm the only downside is you have to remove the warning lamp as it is no longer needed so will be on all the time.
Mark
12 Volt Field Coils - by Zetomagneto - 01-04-2019, 06:19 PM
RE: 12 Volt Field Coils - by Bob Culver - 01-04-2019, 08:07 PM
RE: 12 Volt Field Coils - by Speedex750 - 02-04-2019, 07:58 AM
RE: 12 Volt Field Coils - by Bob Culver - 02-04-2019, 09:43 AM
RE: 12 Volt Field Coils - by Special Bits - 05-04-2019, 10:12 PM
RE: 12 Volt Field Coils - by Bob Culver - 06-04-2019, 07:39 AM
RE: 12 Volt Field Coils - by Zetomagneto - 06-04-2019, 11:21 AM
RE: 12 Volt Field Coils - by Special Bits - 06-04-2019, 02:08 PM
RE: 12 Volt Field Coils - by Bob Culver - 06-04-2019, 08:46 PM
RE: 12 Volt Field Coils - by Speedex750 - 06-04-2019, 10:05 PM
RE: 12 Volt Field Coils - by Bob Culver - 06-04-2019, 10:24 PM
RE: 12 Volt Field Coils - by Winston Teague - 06-04-2019, 10:50 PM
RE: 12 Volt Field Coils - by Zetomagneto - 06-04-2019, 10:54 PM
RE: 12 Volt Field Coils - by Special Bits - 07-04-2019, 12:36 AM
RE: 12 Volt Field Coils - by Zetomagneto - 16-04-2019, 10:52 PM
RE: 12 Volt Field Coils - by Stuart Giles - 17-04-2019, 01:30 PM
RE: 12 Volt Field Coils - by Bob Culver - 17-04-2019, 09:39 PM
RE: 12 Volt Field Coils - by Mark McKibbin - 18-04-2019, 12:19 AM
RE: 12 Volt Field Coils - by andrew34ruby - 18-04-2019, 06:44 PM
RE: 12 Volt Field Coils - by Special Bits - 23-04-2019, 09:56 AM
RE: 12 Volt Field Coils - by Stuart Giles - 23-04-2019, 11:45 AM
RE: 12 Volt Field Coils - by Dave Mann - 24-04-2019, 09:42 AM
RE: 12 Volt Field Coils - by Bob Culver - 25-04-2019, 06:30 AM
RE: 12 Volt Field Coils - by andrew34ruby - 25-04-2019, 09:17 AM
RE: 12 Volt Field Coils - by Dave Mann - 25-04-2019, 10:35 AM
