16-04-2019, 05:16 PM
The red lead needs to be fed from +6V so the +ve terminal of the coil or back to the IGN on the switch panel should suffice. Black wire should be connected to the -ve side of the coil in the same way that the old distributor points were connected. The distributor ground is through the body and I have a second earth lead from the dynamo body to earth to ensure good contact is made.
Peter
Peter
