15-04-2019, 03:48 PM
If the cars have been standing for any length of time, you may find that the crud in the tank has migrated to the fuel pickup area, which is in the little well in the tank just above the drain plug. I suggest you take the drain plug out and drain the tank and refill with a gallon or so of fresh fuel. At the same time, try blowing the fuel line out from the pump connection back to the tank.
